Driving with hubs locked? - JeepForum.com
post #1 of 12 Old 01-29-2002, 09:43 PM Thread Starter
DarkHorse
Question Driving with hubs locked?
How will it affect my Jeep, if I have my hubs locked while NOT in 4WD? The reason I ask is, I lock them while playing in mud, & I don't need to use 4WD unless I have to. Most of the time I am in 2WD until I do get buried, and it's only then, I will switch to 4-low. No problems so far. Just curious to know if there maybe some problems down the road. Thanks.
85' CJ-7 with some goodies...
DarkHorse is offline
post #2 of 12 Old 01-30-2002, 06:40 AM
rivertrout10
rivertrout10's Avatar
Post
I do it without problem as well - I think the only thing that locking your hubs really effects is a little gas mileage. There has been discussion in the forum on this subject before and the general consensus is that it does not cause any damage - especially at lower speeds and in off-road conditions.
Derek
Jeep - its a job - not an adventure
rivertrout10 is offline
post #3 of 12 Old 01-30-2002, 06:58 AM
bodi
Post
They way that I understand it is that it is good to do this on occassions as it seems as if it would help keep the hubs lubbed (sp?).
83 CJ7 w/remanufactured jasper 258 I6 w/t-5, Weber carb, new exhaust, PS, PB, 2 1/2" Lift, 31" BFG's, herculined interior and s**t brown paint job (for now) "in to deep..but thats when it starts getting fun"
Brown Jeep Club Member #2
bodi is offline
post #4 of 12 Old 01-30-2002, 12:53 PM
MR.CJ-7
Post
Another vote for No prob.
I run mine all the time in winter and when flat towing(someone said it helps lube the T-case)
Right now I am running mine continuosly to get some miles on my new R&P.
Former CJ'er
MR.CJ-7 is offline
post #5 of 12 Old 01-31-2002, 06:38 PM
Jack CJ7
Cool
No, keeping the front hubs locked will NOT keep the T-Case lubed. (Dana 300).
To flat tow the CJ, one must either remove the DriveShaft, or install a Warn Full Floating axel kit, with Locking hubs.
This is especially true if a TeraLo 4/1 kit has been installed..
Jack CJ 7
Jack CJ7 is offline
post #6 of 12 Old 02-02-2002, 09:47 AM
MR.CJ-7
Post
Jack CJ 7
Why not? Drive shaft spins T-case gears which causes gear splash right?
Former CJ'er
MR.CJ-7 is offline
post #7 of 12 Old 02-06-2002, 02:21 PM
Jeep Daddy
Jeep Daddy's Avatar
Post
I'm no expert, but I talked to the experts at Jeep R Us and they said the Warn full floating axel kit is best, but if you don't want to spend the extra money, you can stop towing every 300 or so miles and start the Jeep engine. This will splash lube the transfer case.
(Flat Towing is what we're talking about now)
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #8 of 12 Old 02-06-2002, 04:04 PM
West
Post
To get the splash lube you'd need to get the shaft in the transfer case spinning to create splash.
West is offline
post #9 of 12 Old 02-06-2002, 10:52 PM
Jeep CJ5
Post
If you constantly drive with the front hubs locked there will be minor additional wear on the axle components.(I always questioned how much wear there could actually be)
If you are doing it ocassionaly when you are in winter weather or four wheeling I would not worry.
Billy
1974 CJ5 Renegade...restored...100% perfect
too nice to be true!!!
Jeep CJ5 is offline
post #10 of 12 Old 02-06-2002, 11:42 PM
jeepster18_88
Post
If you look at the D300 you'll see that the filler hole is high enough that the rear driveshaft would catch lube as it spins. Otherwise your transfer case would lock up after just driving it a short distance. That's because your transfer case is running all the time. If you don't agree, think about this. Why would the recommended transfer case oil change be the same as the transmission. The lube doesn't go bad sitting in a bottle so therefore it wouldn't in a sealed box. Hope this helps.
Josh
jeepster18_88 is offline
post #11 of 12 Old 02-07-2002, 08:00 AM
T Hoff
1975 CJ5
Post
My thought son locking hubs:
The theory of unlocking the hubs was to help in the gas mileage department and to save the knuckles from abuse on hard road surface.
Well now they make front wheel drive cars and all of a sudden the knuckle issue ..is not and issue.
You can feel the steering wheel grab alittle if you turn the wheel all the way to lock but how often does one do that?
My wifes truck has 250K on the odometer and we have not replace a knuckle yet and as soon as the roads aget a bit slushy..she locks them in.
'75 CJ5 ---Chevy HP 350 motor-- All Fiberglas---one piece tilt forward nose
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
T Hoff is offline
post #12 of 12 Old 02-08-2002, 08:22 AM
MR.CJ-7
Post
Well I am definetly no expert in the T-case dept. One member here suggested it would lube the front. Either was I am not concerned about a prob for the moderate amount I flat tow my CJ. BTW the issue for me is no longer I picked up a car hauler the other day.
Former CJ'er
MR.CJ-7 is offline
driving with the front hubs locked?? good or bad CooterBrown Jeep CJ Forum 14 12-23-2009 07:49 PM
84 CJ won't move when hubs locked-Ideas? erikdane Jeep CJ Forum 4 12-06-2007 04:32 PM
How fast, with hubs locked in 2H amc232 Jeep CJ Forum 6 01-27-2007 02:38 AM
leaving hubs locked in my77cj5levi Jeep CJ Forum 6 12-10-2006 05:51 PM
Running in 4WD With Locked Hubs dmagstadt Jeep CJ Forum 5 02-12-2003 08:09 AM
