Drivetrain Build Advice – Trail and Second vehicle use, for now - JeepForum.com
post #1 of 2 Old 10-20-2009, 12:52 PM Thread Starter
Woolys_CJ7
1976 CJ7
We are starting out with a high mileage (over 250,000) CJ7 with a fresh motor that sat for the last 6 years and turning it into a reliable daily driver that will be used part time (soon to be 16 year old daughter drives my car when needed I take Jeep to work). Besides being a fun let’s take the Jeep, I want to make this a capable trail rig for the desert and mountain trails in Arizona along with an occasional trip to Glamis. I’m currently going through the Jeep to make it extremely reliable, painless wiring and central ground, changing all fluids, replacing any worn suspension and steering components. What I’m asking for is the groups thought on the following plans below.
Current:
• 2.5 inch **** Cepek lift
• 31’s
• Keep the narrow axle look
Planned upgrades:
• Truss and weld the AMC20 axle tubes when I put in one piece axles.
• Detroit Truetrac’s front and rear
• Tube front fenders
• TJ rear flares with body trimmed to match
• 33’s or 35’s
Questions:
• Will 35’s fit with the body modifications and current lift?
• If I go 35’s will I have to re-gear from the 3.54 to?
• Are there narrow track axle upgrades?
Thoughts, what will I break with the larger tires? Other input?
Thanks,
Wooly
Woolys_CJ7 is offline
post #2 of 2 Old 10-20-2009, 01:33 PM
kickingprop
There are NT upgrades the same at the WT axles, but I'd seriously recommend finding a good set of WT axles (that have already been re-geared to 4.10 or so) and swap those in. The gearing will be right for the 33-35" tires.
Trussing and welding the AMC20 will make it plenty strong for those size tires, actually stronger than a Dana44.
As far as Re-gearing also goes...if you are going to put in Tru-Tracs front and rear you'll have to re-set backlash, etc anyway so you might as well (Aggghhh The dreaded MAW's!) re-gear then while everything is out.
Do you run a 4 or 5 speed transmission and will you use it on the highway? this will help determine the best gearing.
TrueTrac's are pretty solid and will do well in most offroading situations.
Front Tube fenders...tons of people make them and they are all great products for the most part I like Kings OffRoad's Products - KORE, King's Off Road, King's Off Road Enterprise, Off Road Chassis Turn-Key Buggies
That link is for the YJ fenders but he always has CJ tube fenders in stock (website just hasnt been updated in a while)
the TJ flares, tube fenders, and body trimming should give you plenty of clearance for 35's if you go to a 4.5" Lift...I dont think 2.5 is going to be enough personally unless you wont be putting it in any flexy situations.
If its going to be getting a lot of city/highway use I'd also consider going to 4 wheel disc breaks. Lots of great DIY writeups out there and complete setups as well depending on how much you want to spend. But power 4wheeldisc brakes will make it MUCH safer to drive than manual drums...
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
CJ-6 Build Plan - Any advice? Agar426 Jeep CJ Forum 12 02-08-2010 08:41 AM
Advice for MUD build Olrev Jeep CJ Forum 18 05-16-2009 01:19 PM
CJ5 Build advice skywalker2117 Jeep CJ Forum 8 02-03-2009 05:24 PM
Trail CJ build ?'s this is long but I like to get others ideas. texascj77 Jeep CJ Forum 13 09-20-2007 10:21 AM
Vehicle Build Sheet Codes? CJ8DV8 Jeep CJ Forum 0 07-24-2002 09:08 PM
