Driveshaft - JeepForum.com
post #1 of 4 Old 10-17-2009, 07:42 PM Thread Starter
jmna
Driveshaft
Hey can anybody advise me on a rear driveshaft for my 1981 CJ7. I have 1981 CJ7 with a chevy 350 GM 4 speed bull dog and np205 transfer case, rear axle is GM 14 bolt running 38 tsl for tires. Im having a hard time with this due to the pinion angle and will a stock drive shaft work any advise would be great thanks.
jmna is offline
post #2 of 4 Old 10-17-2009, 07:45 PM
BriansCJ
1994 XJ Cherokee
I doubt a stock axle shaft will work in length, let alone hold up to a V8 and 38.5" TSLs.
Call Tom woods or High Angle Driveline. Ive heard good things about both of them
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #3 of 4 Old 10-18-2009, 01:17 AM
gojeepin
1983 CJ7
Originally Posted by jmna View Post
... Im having a hard time with this due to the pinion angle and will a stock drive shaft work any advise would be great thanks.
A couple of bits of info could help us a lot...
1) What is the pinion yoke angle?
2) What is your TC yoke angle?
3) What gearing you have... if it's numerically low you'll put more stress on the driveshaft.
Your stock driveshaft (single cardan) will only work if it's the correct length and the angles match. Most times that means the rotational center of the TC output and axle input are parallel. Make all your measurements with the vehicle on its wheels at ride height.
Click here then see section on driveline
Tom Woods site will help you determine how to take length measurements.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 4 Old 10-19-2009, 08:49 AM
CSP
See the tech pages at www.4xshaft.com (Tom Wood's site) to see how the angles should be depending on what type of driveshaft you have.
CSP is offline
XJ Front driveshaft used as a rear driveshaft CJ5911 Jeep CJ Forum 24 11-02-2012 07:17 PM
CJ5 driveshaft help. amerson80 Jeep CJ Forum 6 01-06-2009 09:24 PM
Which driveshaft for 79 CJ5 BaseballFan75 Jeep CJ Forum 4 12-13-2008 05:03 PM
driveshaft ?'s wjr Jeep CJ Forum 2 06-08-2007 10:01 AM
where to get used driveshaft? NJCJ7 Jeep CJ Forum 5 03-06-2004 08:56 AM
