Driveline Vibrations - JeepForum.com
post #1 of 5 Old 12-13-2007, 06:51 AM Thread Starter
fatterman
fatterman's Avatar
Ok I am getting close on this and cant quite get it to go away, I have a CV Driveshaft and it is within 1* at the rear yoke I get the usual "cyclical vibration" between 50-55mph slower than that and above that there are no vibrations only in that speed range, what else could it be, my driveshaft is a TomWoods and had the same problem with my old driveshaft (So I dont think that it is out of balance). I have a 4" suspension lift.
fatterman is offline
post #2 of 5 Old 12-13-2007, 11:42 AM
jpfaris
1979 CJ7
check your toe in and tire balance
79 CJ7, 304, TF727, D300, FULL WIDTH D44's, 4.56:1, SPOOL LOCKERS, SOA, OUTBOARDED, SHACKLES REVERSED, HOMEMADE D-SHAFTS, 38.5" BOGGERS
jpfaris is offline
post #3 of 5 Old 12-13-2007, 12:25 PM
Mike Romain
I get noises at that speed when a tire is out of balance. That seems to be about where tires change from compression (going slow) to expanded (going fast) so they float a bit there and if out of balance it will harmonic and show there first.
After a bit of this, the tread usually scallops...
Mike
Mike Romain is offline
post #4 of 5 Old 12-13-2007, 04:01 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
a worn pinion bearing will do this also,.
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #5 of 5 Old 12-14-2007, 12:07 AM
T18A
1977 CJ5
T18A is offline
more vibrations calcallender Jeep CJ Forum 9 06-11-2007 03:00 AM
Vibrations 81CJ7Renegade Jeep CJ Forum 2 01-28-2006 04:23 PM
Vibrations in the Clutch CJWolf Jeep CJ Forum 5 05-05-2005 12:35 PM
driveline vibrations joe johnson Jeep CJ Forum 2 04-05-2004 03:58 PM
