driveline angle in a cj5? - JeepForum.com
post #1 of 7 Old 06-30-2007, 12:03 PM Thread Starter
4wheelinfool
4wheelinfool's Avatar
1980 CJ5
i want to put a 4.5" rubicon express lift on my new 80' cj5 and a 1" body lift, but am curious if i have to do any driveshaft or t-case upgrades? any input would be greatly appreciated! thanks
R.I.P one Baddass 92' yj that had 5.5in in the front and 6in in the RR with 33x 12.5's Baja Claws with homemade everything and a whole lot of sweat, blood, and tears that went into her......... But i did just get an 80' cj5 that is getting 4.5in RE, 1in Daystar, bushwackers, winch, and ox lockers, gears, and some meaty 35in BFgoodridge Krawlers.. oh yeah baby
4wheelinfool is offline
post #2 of 7 Old 06-30-2007, 12:18 PM
80cj
80cj's Avatar
1980 CJ5
I am sure you will have to adjust your U joint angles. I have only a one-inch lift on mine right now and have 18 degrees at the pinion and experience vibrations at certain speeds. I have a Skyjacker 2.5" kit waiting to be installed and I bought a set of 2.5 degree wedges to lessen the pinon angle. I imagine I will have to lower the transfer case also. I'm running 4.10 gears. Mine is an 80 CJ-5 too.
80cj is online now
post #3 of 7 Old 06-30-2007, 02:22 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I run the RE 4" YJ Standard lift on my 80 CJ5. I rotated the pinion up and used a 1" drop on the transfer case. No vibes. I would feel better using a CV shaft though.
BESRK is offline
post #4 of 7 Old 07-01-2007, 01:19 PM Thread Starter
4wheelinfool
1980 CJ5
is there a SYE kit for the dana 300? cause i've never heard of one, if so, is all i'll need is a cv driveshaft?
post #5 of 7 Old 07-01-2007, 02:16 PM
80cj
80cj's Avatar
1980 CJ5
No SYE for the D 300. 80 D300's have a short output shaft. So that's as good as it gets. 81 and later D300 have a longer shaft, FYI. Yeah, sounds like you have a CV shaft in your future.
80cj is online now
post #6 of 7 Old 07-01-2007, 10:11 PM
kbtriumph
kbtriumph's Avatar
There is no slip yoke to be eliminated on a 300 case.
'43 GPW Rock Crawler
'74 CJ6 Safari
'98 TJ DD
kbtriumph is offline
post #7 of 7 Old 07-02-2007, 09:10 AM
COBRA5LADDICT
my 80 has an alcan 4" lift short output d300 dana 44 rear and a cv shaft.. NO t-case drop and so far no vibes.
COBRA5LADDICT is offline
80CJ7 driveline angle wrong pajeepfreak Jeep CJ Forum 2 10-05-2009 07:27 AM
skid plate/ driveline angle setup help rustymudder Jeep CJ Forum 4 07-20-2009 04:11 PM
Driveline Angle Specifics 84MSRB Jeep CJ Forum 2 10-18-2008 04:53 PM
t case to rear axle driveline angle firejeep344 Jeep CJ Forum 3 07-01-2008 10:07 PM
driveline angle? nichols077 Jeep CJ Forum 7 03-20-2007 09:39 PM
