driveline - JeepForum.com
post #1 of 2 Old 12-09-2004, 09:53 AM Thread Starter
wilf
driveline
on my 82 cj5 they just installed a 4 inch pro comp lift and they said i needed to get my driveline extended. there is a place here in okahoma that does it called driveline specialist or somethin like that so its no big deal to get it done but is that a normal thing to have to do. we just put the same lift on a 92 yj and did not need to do that so i was just curious. thanks, Blake.
wilf is offline
post #2 of 2 Old 12-10-2004, 06:26 AM
gosupes
Your 5 is quite a bit shorter than the YJ. It depends on how much room you have left in the slip joint. You don't want to seperate it on the trail somewhere. Depending on the angle, look into a CV style shaft also. Usually it's cheaper to build a new shaft rather than lengthen an old one.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
Driveline Vibrations fatterman Jeep CJ Forum 4 12-14-2007 12:07 AM
79 CJ7 driveline question billyroy Jeep CJ Forum 2 11-23-2007 05:13 AM
driveline angle in a cj5? 4wheelinfool Jeep CJ Forum 6 07-02-2007 09:10 AM
Driveline noise madadsnt Jeep CJ Forum 1 03-21-2007 08:55 PM
CJ DriveLine sefh Jeep CJ Forum 13 09-27-2006 10:08 AM
