Drive shaft questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Drive shaft questions
KrawlOff-Road.com now Carries Iron Rock Off Road!!!!!Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 05-12-2014, 12:06 PM   #1
Stelly1227
1977 CJ7
Has anyone made their own drive shaft with parts from a tractor supply store? Would these work or would they not handle the hp? I have a sbc 350 with t-19. Any advice on the matter please
Stelly1227 is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 12:16 PM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Tractor shafts are relatively low speed, but pretty heavy duty. That said if you made it right and found a place to balance it, it should work.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 12:17 PM   #3
TIPPEDITOVER
In the garage
TIPPEDITOVER's Avatar
1978 CJ5
All I've ever personally done is hacked up a junkyard drive-shaft to meet my needs. Unfamiliar with the parts you are referring to from the tractor supply.
Shaun
What's that strange noise?
TIPPEDITOVER is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 12:19 PM   #4
CSP
The tolerances on the slip joint are too loose on the tractor parts. It would vibrate like mad at highway speeds.
I have three tractors that use PTO equipment on the three point and you can see the driveshafts moving around when it's running. Those shafts only spin at 540RPM.
CSP is offline   Reply With Quote Quick reply to this message
Unread 08-30-2014, 03:29 PM   #5
Stelly1227
1977 CJ7
Ok I found my old drive shaft but it has a good wobble to it. If I were to cut out the bent part and change it out. What would I use to make it. What would be the best material to use
Unread 09-04-2014, 10:49 AM   #6
TIPPEDITOVER
In the garage
1978 CJ5
Go to the junkyard and pull a DS with the same size tube as the one you have. Splice in the needed tube to make the repair. It's a little bit of a crap shoot because it's tough to tell the wall thickness or inner diameter of a jy ds and it might differ from what you have, but it's worked for me in the past.
Unread 09-04-2014, 07:19 PM   #7
dg6772
I've done this too....I prefer to replace the entire shaft myself.
A local shop can lengthen or shorten your ds as well. For a price, but around here,to shorten is about 50.00, lengthen varies some. I've paid from 75.00-150.00 for that.
Dave in Muskegon using Jeep Forum App
dg6772 is offline   Reply With Quote Quick reply to this message
Unread 09-04-2014, 07:40 PM   #8
Savemycj
Junior Member
Savemycj's Avatar
1975 CJ5
You can get double cardan driveshafts (front of Cherokees and TJs I think?) from junkyards and have them shortened to fit front or rear. These can handle angles better.
Savemycj is offline   Reply With Quote Quick reply to this message
Unread 09-05-2014, 09:58 AM   #9
TIPPEDITOVER
In the garage
1978 CJ5
If you do decide to go double cardan, then you have to change the t-case output yoke, because it is very different in all aspects. Also you must rotate the rear axle pinion up to point at the t-case yoke. If you don't need double cardan then don't do it. Keep it simple as possible.
Unread 09-08-2014, 07:42 AM   #10
Newbjeep
1972 CJ5
Can you elaborate a little on this? Where would I get the yoke from? Im doing a t18 swap and am pretty sure ill need a double cardan shaft as my single is at a pretty steap angle now with the t150
Newbjeep is offline   Reply With Quote Quick reply to this message
Unread 09-08-2014, 07:57 AM   #11
CSP
The bolt hole spacing is different and the bolts pass from the transfer case side of the yoke and screw into the CV joint.
The yoke availability depends on which tcase you have. The D300 and 26 spline Dana 20 can use the yoke off the front of an XJ tcase or 79 and older Qtrac fullsize Jeep case. Driveline suppliers also have them.
Unread 09-08-2014, 08:33 AM   #12
Newbjeep
1972 CJ5
Ok I have 2 of the dana 20 tcase's one from a j truck and the stock one from my cj5 would either of those be a 26 spline and is there a specific year xj that the front yoke fits my rear? Also do I use the front xj shaft or the rear?
Unread 09-08-2014, 10:18 AM   #13
CSP
Count your own splines to determine if either is 26 spline.
XJ with NP231 tcase has the right yoke. Surely you can google to find out what years those are.
Unread 03-01-2015, 07:32 PM   #14
Stelly1227
1977 CJ7
Does anyone know what vehicle would take the same size u-joints as a factory 77cj7
Unread 03-01-2015, 09:15 PM   #15
CSP
Lots of vehicles use the 1310 ujoint. What's your idea?
