drive shaft question - JeepForum.com
post #1 of 2 Old 10-20-2011, 07:16 PM Thread Starter
nickmimi
2011 JK Wrangler
I am trying to convert my cj7 from SOA to SUA. I have a line on some stock drive shafts. Based on my engine and transmission I need to have 31.75 in the front and 20.75 in the rear.
The ones I am trying to buy are 30.25 front and 20.5 in the rear.
Any idea if these would be acceptable with a 2 inch lift?
Thanks
2011 JK unlimited Sahara Tan rubicon
nickmimi is offline
post #2 of 2 Old 10-20-2011, 09:14 PM
mopar346
A 1/4 in the rear should be no issue, just make sure you have plenty of slip in the yoke in both directions. The front may be an issue, 1.5 inches may take you out of acceptable slip range, it is the front and I would guess it requires more slip in the extended side so you are losing 1.5 of travel right off the bat. If not bouncing is planned you maybe OK.
Careful your character's showing
mopar346 is offline
Drive shaft angle / drive shaft length / 2.5 inch lift GlennLever Jeep CJ Forum 6 10-22-2011 04:40 PM
Drive shaft question dupont12 Jeep CJ Forum 4 07-11-2011 04:13 PM
CV drive shaft question SavannahCJ Jeep CJ Forum 8 05-13-2010 08:50 AM
Drive shaft question bad64chvlle Jeep CJ Forum 9 04-09-2009 12:26 AM
drive shaft question 81cj7mudder Jeep CJ Forum 9 10-30-2005 06:54 AM
