drive shaft :( - JeepForum.com
post #1 of 4 Old 03-01-2005, 09:22 AM Thread Starter
thenubsterman
Unhappy drive shaft :(
Hey i was wondering if anyone has a used driveshaft that is still in good shape because mine is shot, i have the u joint bearings welded onto it, and ya I have a 360, hooked up to a t 150 and model 20 t case so idk the measure of the driveshaft but maybe someone can help me out.
thenubsterman is offline
post #2 of 4 Old 03-01-2005, 10:00 AM
boaman88
I don't have a shaft to sell but I did have exactly the same set-up you do at one time. I was breaking u-joints with the 360 quite often. Bought a set of Spicer blue seal u-joints and never broke one again. Welding anywhere near the u-joint does damage to the bearings. I suggest getting a new shaft and decent u-joints. I also suggest using U-bolt yokes over the strap type if you don't already have them. I'm sure some of the times I thought I was breaking a joint, I was really breaking the bolts or straps instead.
boaman88 is offline
post #3 of 4 Old 03-01-2005, 11:49 AM
tbicj7
Check out www.highangledriveline.com. Jess has the best shafts on the market. I'm running his shafts and haven't broken anything yet. (2yrs) He uses .250 walled 2.5" tubing, and what ever joints you want. I opted for the 1350 on mine. Hope this helps.
Vegore the Wonder Tomato 83 CJ7 TBI 350 smog legal conversion Bowtie stage 3 700r4 D300 w/twin stick Dana 44's front and rear 4.56's locked up at both ends high angle drivelines f/r Xtreme offroad high steer conversion currie steering box brace all custom SS braided lines 37" MTR's warn XD9000i SOA wrangler springs(all rears)slickrock hangers currie bumpers front and rear w/full size spare, full family cage simpson harnesses and tuffy boxes. The list goes on and on.
R.I.P.
08 on the way
tbicj7 is offline
post #4 of 4 Old 03-01-2005, 03:50 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Measure the distance from center of ujoint to center of ujoint and post up that length. I have a few driveshafts laying around...maybe a match?
BESRK is offline
Grand Cherokee Drive shaft/CV Shaft jollyroger Jeep CJ Forum 5 12-13-2011 05:31 PM
Drive shaft Wmasseyiv Jeep CJ Forum 1 02-15-2008 08:39 PM
CJ7 CV Drive Shaft? Face Jeep CJ Forum 5 02-13-2008 10:46 PM
drive shaft? bulljeeper Jeep CJ Forum 20 02-01-2007 08:28 PM
Drive Shaft ??'s sefh Jeep CJ Forum 2 11-18-2005 09:02 AM
