Drilling out Venturi tubes in Carter carb - JeepForum.com
post #1 of 9 Old 05-20-2003, 04:22 AM Thread Starter
CJOOP7
I have a stock '83 CJ7 6 cyl and carter carb. I removed the venturi cluster and ran needles through the venturi tubes to clean them out. I read on another forum that Jeep recommends you drill them out to 0.032 inches and your engine will idle better and not stall (like mine does).
Here's the ?, where do you get a 0.032 drill bit ? By my calculations thats a 1/31.25. I don't think I've ever seen that size. Are they really referring to a 1/32 bit? Has anyone ever done this, does it help? Should I stop asking questions now so someone can answer this?
Joop
CJOOP7 is offline
post #2 of 9 Old 05-20-2003, 08:26 AM
fuzz401
1978 CJ7
try a set of number drill bits from 61 to 80
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 9 Old 05-26-2003, 10:20 PM
CaptFDU
Got mine at ACE Hardware and drilled em out. Runs a little better but doesn't solve the problem. It does help...
Capt. Trip Franklin
Florida Down Under, Inc.
84 CJ7//258//T-176//Dana300
31 AT's//Nutter Bypass
TFI upgrade//Sway Bars Removed
8000lbs Winch//SOA in the works
CaptFDU is offline
post #4 of 9 Old 05-27-2003, 11:12 AM
40Below
40Below's Avatar
I too just had to do the drill out of the idle jet fule pick up tubes. the drill is a #67 that I had no problem finding at local hardware store. Seems to have fixed the idle issues.....
84 CJ7 Laredo 258/T5 herced tub 86/D44 4.5"RE lift, 33Xterrains and a TWoods CV driveshaft Custom bumpers and tire rack.Blue Jeep Club #140
40Below is offline
post #5 of 9 Old 05-28-2003, 05:07 PM
CJ7Danny
The best thing for that Carter is to use as anything esle but a carbuerator!!! For 119 bucks at Autozone, you can get a motorcraft carb that will run exponentially better than that carter EVER will. Of course, I did the swap as I was completing the nutter by-pass. Total cost of the project was less than 175 bucks. Been on two very serious trail rides so far and it has by far been the best carb I've ever experienced off-road. Even better than the 385 dollar webber!
What you need is a MC2100 carb w/ 1.08 venturi size (I used one of an 1975 CJ5 w/ a 304)
Mr. Gasket adapter PN 1875 (i think)
5 1/8" air filter assembly.
I'm telling you... ditch that Carter...best thing you can ever do for that 258
Dano
85 CJ7 Laredo Hard Top
33" BFG M/T
T176
Moser One Piece Axles
D300, D30, AMC 20, 258 ci
Motorcraft 2100 swap
Nutter By-Pass
Custom front bumpers
Custom Rear bumper/tire carrier
CJ7Danny is offline
post #6 of 9 Old 05-28-2003, 05:50 PM
bernie
Don't forget the ignition system, either.
I rebuilt my stock carb, and it ran much better.
I still thought it should idle/run better.
I read that the high mileage Duraspark ignition system could cause idle problems, as well as many other performance/driveability issues.
I installed GM HEI, and this jeep has never run better.
All my idle problems, as well as many other performance issues, are gone--and I am still running the Carter carb.
Yes, I want to upgrade the fuel system, but I have a long list of what I want... :-)
someday...
Hope this helps
bernie is offline
post #7 of 9 Old 05-28-2003, 09:34 PM
HighCountry
I plugged the ports that the "stepper motor" on the back of the Carter operates and also performed the "Nutter Bypass" and my '86 258 runs flawlessly and gets great mileage. Open the hood for the "Smog Police" and everything looks TOTALLY stock! Also, if it ever comes to it I can UN-modify my system in about an hour for $0.00...
Bruce from West LA (Lower Arkansas)
HighCountry is offline
post #8 of 9 Old 05-29-2003, 10:31 AM
Popol
Popol's Avatar
what is a nutter bypass?
Popol is offline
post #9 of 9 Old 05-30-2003, 05:01 AM
sampson9dk
Popal
How is the Jeep running...are you divorced yet? This is the Nutter Bypass.
http://www.4x4wire.com/jeep/tech/ele...jn-ignition99/
...The Carter is junk..dont waste your time drilling....my MC2100 is simple, cheap and runs like a top. Around $32 on ebay and $16 for the rebuild kit at advanced auto
sampson9dk is offline
Carter Carb Help----Carb Guru's Goody1231979 Jeep CJ Forum 4 04-28-2009 06:03 PM
Carter AFB carb issue (general carb) danheit Jeep CJ Forum 1 04-19-2009 05:34 PM
New shorter Carter BBD Idle Pickup Tubes? Jeepin_XJ_101 Jeep CJ Forum 1 01-21-2009 04:13 AM
Carter Carb vent tubes dbd Jeep CJ Forum 5 10-06-2008 05:07 AM
Carb 121 venturi, too big? Etchandy Jeep CJ Forum 1 06-30-2007 09:51 PM
