drb2 fution to reduce Mopar mpi timing - JeepForum.com
post #1 of 6 Old 11-15-2012, 11:21 PM Thread Starter
dandd
1982 CJ8
I will be getting the use of a DRB2 scan tool next week. The purpose is to reduce the timing in a Mopar MPI conversion. "pinging"
I would like to know if anyone can give me a basic explaintion on how to do this and what other conponents are required (super card, flash card, jeep card, ...)
Thanks
dandd is offline
post #2 of 6 Old 11-16-2012, 04:36 AM
86cj74.2L
86cj74.2L's Avatar
Thanks
I wasn't aware that you could do any tuning with the drb with the exception of target idle rpm.....possibly. If you can tweek timing tables that would be nice to know.
86cj74.2L is online now
post #3 of 6 Old 11-16-2012, 04:53 AM
gmakra
Tell me more about the conversion is it a Hesco/Mopar kit? Did you bump the compression, change cams that kind of stuff?
You may need to get a MAP adjuster cause if your running the 4.0 dizzy its not really adjustable.
This may help you in the meantime http://www.splitsec.com/products/psc1/PSC1003.htm
The 4.0 MAP is not easily hacked to make adjustments. However there is a guy on Jeepstrokers that seem to be able to massage the ECM.
gmakra is offline
post #4 of 6 Old 11-16-2012, 11:02 AM Thread Starter
dandd
1982 CJ8
My understanding and post from Hesco (Mopar MPI support) the max timing is adjustable in 2 degree increments for a total of + or - 6 degrees.I was told this can happen with a DRB2 not a DRB3. I’m not sure of the program card to use.
The engine is a stock rebuild from titan motors in Florida so the compression is stock plus their machining. Stock cam, exhaust manifold, 195 therm, Hesco suggested cooler plugs.
What is 4.0 Dizzy?
dandd is offline
post #5 of 6 Old 11-16-2012, 02:09 PM
gmakra
Dizzy is distributer
gmakra is offline
post #6 of 6 Old 11-24-2012, 09:53 PM Thread Starter
dandd
1982 CJ8
how to adjust with DRB
If you have a Moper MPI Kit (Hesco) this is how to retard timing with a DRB2 scan tool.
1. Plug SCI cable into DRB2, power and into computer interface plug.
2. Plug in super cartridge.
3. menu 1 press 4 select systems
4. menu 2 press 1 engine
5. menu 3 press 2 without A/C
6. menu 4 press 1 Fuel/Ignition
7. menu 5 press 5 Adjustments
8. menu 6 press 5 Spark Advance
9. menu 7 Spark Advance Adjustment
At this point you have the option to adjust the advance a total of -6 degrees in two degree increments.
After taking out -4 degrees the engine idles smoother and no issues with pinging, at last.
dandd is offline
