Drag link hitting passenger leaf spring SUA - JeepForum.com
post #1 of 12 Old 11-03-2013, 04:30 PM Thread Starter
acourt
1983 CJ7
Need help figuring out best options on my newly purchased CJ. My guess is that the spring sag is so bad that the drag link is hitting the top of the passenger spring. The springs appear to be factory,(4 leaves in the pack) but I could be wrong.
I won't be wheeling much, but want to enjoy decent ride quality on the street. I'm thinking of just buying factory springs for the front, since the rear appears to be fine...
acourt is offline
post #2 of 12 Old 11-03-2013, 04:51 PM
skizriz
1978 CJ7
Does it have a dropped pitman arm on it?
Take a picture of the drag link and tie rod straight on from the front, level with them.
skizriz is offline
post #3 of 12 Old 11-03-2013, 05:51 PM Thread Starter
acourt
1983 CJ7
It currently has a standard, but worn out pitman arm. The drag link is about parallel to the ground... I'll get a better pic tomorrow.
acourt is offline
post #4 of 12 Old 11-03-2013, 06:07 PM
LeePrather
1978 CJ5
Mine rubs on the leaf as well. One option is a flip of the tie rod/drag link. I'm not sure how changing the leaf pack will lower it? In order to not rub, the leaf needs to drop lower?
LeePrather is offline
post #5 of 12 Old 11-03-2013, 06:53 PM
82JeepCJ7
1982 CJ7
Check your U-bolts.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #6 of 12 Old 11-04-2013, 06:22 AM
gmakra
You could do a tie rod flip.
gmakra is offline
post #7 of 12 Old 11-04-2013, 08:28 PM Thread Starter
acourt
1983 CJ7
Here are updated pics from the other side to give more perspective. U-bolts seem tight, but I've not placed a wrench on them yet... if I flip the draglink don't I have to bore the hole to accept the taper correctly?
acourt is offline
post #8 of 12 Old 11-04-2013, 08:59 PM
skizriz
1978 CJ7
Thats your problem. A drop pitman arm with stock springs.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #9 of 12 Old 11-04-2013, 11:42 PM
Spieg8
1984 CJ8
Yep, that's the problem right there.... put on a stock pitman and you will be fine.
Spieg8 is offline
post #10 of 12 Old 11-05-2013, 07:16 AM Thread Starter
acourt
1983 CJ7
Thanks guys. The PO said something about swapping the steering box... guess he left the pitman arm on it when he swapped it. I have a spare if I ever do a lift. New pitman should be here this week.
acourt is offline
post #11 of 12 Old 11-09-2013, 07:04 PM Thread Starter
acourt
1983 CJ7
Here's the rest of the story... new pitman installed, plenty of clearance.
acourt is offline
post #12 of 12 Old 11-09-2013, 07:14 PM
skizriz
1978 CJ7
Looking at how short the old one was, your turning radius will improve also.
skizriz is offline
