-   -   Drag link hitting passenger leaf spring SUA (http://www.jeepforum.com/forum/f8/drag-link-hitting-passenger-leaf-spring-sua-1753954/)
acourt 11-03-2013 03:30 PM
2 Attachment(s)
Need help figuring out best options on my newly purchased CJ. My guess is that the spring sag is so bad that the drag link is hitting the top of the passenger spring. The springs appear to be factory,(4 leaves in the pack) but I could be wrong.
I won't be wheeling much, but want to enjoy decent ride quality on the street. I'm thinking of just buying factory springs for the front, since the rear appears to be fine...
skizriz 11-03-2013 03:51 PM
Does it have a dropped pitman arm on it?
Take a picture of the drag link and tie rod straight on from the front, level with them.
acourt 11-03-2013 04:51 PM
It currently has a standard, but worn out pitman arm. The drag link is about parallel to the ground... I'll get a better pic tomorrow.
LeePrather 11-03-2013 05:07 PM
Mine rubs on the leaf as well. One option is a flip of the tie rod/drag link. I'm not sure how changing the leaf pack will lower it? In order to not rub, the leaf needs to drop lower?
82JeepCJ7 11-03-2013 05:53 PM
Check your U-bolts.
gmakra 11-04-2013 05:22 AM
You could do a tie rod flip.
acourt 11-04-2013 07:28 PM
2 Attachment(s)
Here are updated pics from the other side to give more perspective. U-bolts seem tight, but I've not placed a wrench on them yet... if I flip the draglink don't I have to bore the hole to accept the taper correctly?
skizriz 11-04-2013 07:59 PM
Thats your problem. A drop pitman arm with stock springs.
Sent from my HTC One SV using JeepForum
Spieg8 11-04-2013 10:42 PM
Yep, that's the problem right there.... put on a stock pitman and you will be fine.
acourt 11-05-2013 06:16 AM
Thanks guys. The PO said something about swapping the steering box... guess he left the pitman arm on it when he swapped it. I have a spare if I ever do a lift. New pitman should be here this week.
acourt 11-09-2013 06:04 PM
2 Attachment(s)
Here's the rest of the story... new pitman installed, plenty of clearance.
skizriz 11-09-2013 06:14 PM
:thumbsup: Looking at how short the old one was, your turning radius will improve also.:cheers2:
The time now is 07:24 AM.
