Originally Posted by TetanusCJ7
Just spent 3 hours in the garage (thought it would take 45 minutes). All I am trying to do is run offroad lights off an aux fuse box. I am using a Dorman 4 prong relay. I have a positive power wire running into the aux fuse panel from the positive battery cable. From the aux fuse panel I want to run a Dorman relay for my offroad lights. I have the ground and the power into the relay figured out (ground blade 86, power from battery into blade 30). Now how do I run a toggle switch for the lights? Blade 85 goes to the switch right? Where does the other wire from the toggle go?
Obviously I am new at this electrical/relay stuff and I thought I asked the right questions in my other threads. Now I am stumped. Am I going about this wrong?
Sorry guys, I still don't get it. I am not using any ignition power. My toggle switch has 3 prongs. Off, on, ground. How do I wire this to the relay straight from the aux fuse box?
Here are two awesome explinations on how relays and switches work:
Relays:
http://www.bcae1.com/relays.htm
Switches:
http://www.bcae1.com/switches.htm
OK about your switch. You are going to run into a lot of problems until you understand your switch. IT will be impossable to wire the relay up until we learn how your switch operates. As of right now, I'm not sure I understand your switch.
Normally a 3 prong switch will have a common terminal (center pole) and two switched terminals (SPDT) (Single Pole Double Throw) . But with the latest fad of illuminating the switches you have one terminal for power. one terminal for ground and one to switch off and on the device you want to control.
With the first type of switch, your basic SPDT you have more otion on how to hook it up. With the second Illuminated switch you are stuck hooking it up only one way. You need to supply power for the light and ground for the light. So two of you terminals are already used. Sometimes you can wire the switch so the light is on all the time or only when you turn the device on. I prefer to wire them so they come on when the ignition is on. A switch is no good if you can't find it in the dark. I would prefer to have it dim when the ignition is on and very bright when the device is on but I digress now.
In you case we need to find out what the terminals really are named. Do you have a link or can you take a picture of the instructions? I can guess but that might take up a lot of time.
Here is what I think you will end up with but without knowing the label on the switches I cannot be sure.
