Door fitment - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Door fitment
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaSave 17.76% for the 4th of july with ruffstuff specialties
Unread 02-23-2014, 11:40 AM   #1
Chstock
Door fitment
Alright! So today we went to put on the doors I just picked up off of Craigslist. The drivers side door fit relatively easily. On the passenger side however, the bottom of the door fits in but he top section of the tub on the engine side is about 1/4 of an inch too tight. We somehow need to spread it enough to make room for the door. Is there a tool for this or any suggested way to do this?
Chstock is offline   Reply With Quote Quick reply to this message
Unread 02-23-2014, 02:26 PM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Check the body tub mounts for rust. The mount behind the door controls the top of the opening. You may need to replace it or shim it to open the gap.
My tub is 'glass and I had to fine tune all the mount heights to make everything fit square.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
Unread 02-23-2014, 03:04 PM   #3
cjjon7
1983 CJ7
Loosen the hinge plates on the door, close the door/align, tighten the hinges.
cjjon7 is offline   Reply With Quote Quick reply to this message
Unread 02-23-2014, 04:42 PM   #4
Chstock
The problem is actually the physical place of the metal. It's not a hinge problem. The tub has been in an accident before
Unread 02-23-2014, 07:13 PM   #5
Spieg8
1984 CJ8
Back when I worked summers in the body shop, we used a hydraulic ram (porta-power) for stuff like this. A high lift jack would probably work too although not as easily. Be aware that shifting the tub that much will probably crack the paint and any body filler in the area will probably pop off.
Spieg8 is offline   Reply With Quote Quick reply to this message
