Dome/Courtesy/Under Dash Lights. - Page 3 - JeepForum.com
post #31 of 35 Old 12-31-2012, 12:21 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Yes A relay would work fine. Run constant power to the relay and use the ground on the headlight switch to turn the relay off and on . Run power for the courtesy lamp function through the switched part of the relay.
John Strenk is online now
post #32 of 35 Old 12-31-2012, 01:37 PM
Crazyray2929
1981 CJ7
I have one on the roll bar...One on the dash lip...2 red courtesy lights on a switch up under the dash.
Crazyray2929 is offline
post #33 of 35 Old 01-01-2013, 01:05 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
^^ looks like a license plate light from a trailer or something...
Rick
Cutlass327 is offline
post #34 of 35 Old 01-01-2013, 02:19 AM
Crazyray2929
1981 CJ7
That's exactly what it is.
post #35 of 35 Old 11-15-2013, 03:32 PM
258
Originally Posted by keith460 View Post
They were standard on the Laredo and Renegade package or part of the Convenience Group option.
Not hard to hook up, there should be a couple of leads under the dash that ALL CJ's in the 80's have. One orange colored wire for power with a black colored connector and a black 'ground' wire coming off the Headlight Switch. The black wire will connect to the courtesy lights blue wires.
Hi, I was wondering if you could HELKP me and tell me specifically how to wire the courtesy lights? (1895 CJ7-258)
I have had the OEM lights for a very long time but removed them years ago because someone had previously clipped the wires. They work and look great but are cut. I want to connect them exactly the way they were intended from factory; which is to the headlight light switch and the inside dome connection. (when light knob locks all the way to the left)
What I have, are both lights with each having a solid BLUE wire coming out of the light along with a solid BROWN wire. On one light, the solid BROWN has a Packard 56 type terminal that converts into a BROWN/BLUE STRIPE wire at that terminal. That BROWN/BLUE STRIPE wire is cut about 4" from the terminal that joins them. The blue wire from this same light has a bullet type rubber terminal which continues BLUE from that terminal. That plug of that terminal at rubber boot from BLUE wire is BLACK. This is the one light and on the BLUE side of wire.
The other light simply has a solid BLUE and a solid BROWN wire. It is about 12" long and then it is cut as well.
Can you help me figure this out? If you have the ORIGINAL lengths of each light wire, maybe I can rewire the entire set-up with new wires. Again, I would like to have them exactly the way they were made from factory.
Regards
258 is offline
Dash lights.! MHSJEEPKID2012 Jeep CJ Forum 3 10-15-2009 03:07 PM
Courtesy Lights Have Me Stumped Balvar24 Jeep CJ Forum 12 04-15-2009 12:35 PM
dash lights and head lights "pulse" slightly CrazyHorse6 Jeep CJ Forum 17 02-16-2009 01:20 PM
no brake lights and no dash lights boydog40 Jeep CJ Forum 6 03-01-2006 06:49 PM
dash lights out! help!! edge1 Jeep CJ Forum 14 10-17-2004 10:36 PM
