Dome/Courtesy/Under Dash Lights. - Page 2 - JeepForum.com
post #16 of 35 Old 12-30-2012, 07:03 AM
row684
I believe the under dash lights were a Larado thing, mine came with them. I love them combined with the hardtop dome light now trying to figure out how to put some in my non Larado CJ to.
row684 is offline
post #17 of 35 Old 12-30-2012, 07:53 AM
PROJECT 23
They actually came in Renegades as well. I just pulled a set from an 84 CJ7 Renegade. Trying to figure out how to hook them up....
PROJECT 23 is offline
post #18 of 35 Old 12-30-2012, 11:25 AM
keith460
Jeep. There's Only One
keith460's Avatar
They were standard on the Laredo and Renegade package or part of the Convenience Group option.
Not hard to hook up, there should be a couple of leads under the dash that ALL CJ's in the 80's have. One orange colored wire for power with a black colored connector and a black 'ground' wire coming off the Headlight Switch. The black wire will connect to the courtesy lights blue wires.
1984 CJ-7 Renegade
keith460 is offline
post #19 of 35 Old 12-30-2012, 12:13 PM
lucdog
lucdog's Avatar
1980 CJ5
IIRC the lights have 12v positive all the time. The switch completes the ground. The switches for the doors when open also complete the ground.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #20 of 35 Old 12-30-2012, 12:20 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Interesting to know, but now you have me wondering. Mine has them, but no tach, leather, clock, etc., so I guess a PO installed the lights at some time.
What else would be in the convenience group for a 78? Repainted, new body, so no idea on if it was base model or anything more...
Rick
Cutlass327 is offline
post #21 of 35 Old 12-30-2012, 05:09 PM
keith460
keith460's Avatar
Convenience Group consisted of intermittent wipers, courtesy lights, underhood light, lockable glove box, day and night mirror. I'm not sure the intermittent wipers and lockable glove box were included in 1978 but became available in 1981 or 82.
Tachometer and Rally Clock were their own option but included both.
1984 CJ-7 Renegade
keith460 is offline
post #22 of 35 Old 12-30-2012, 07:53 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Well, I have under dash lights, and day/night mirror. So I guess I have PO installed extras. No locking glove box.
Thanks Kieth!
Rick
post #23 of 35 Old 12-31-2012, 01:59 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Bill
That's right.
The headlight switch also operates them as well when you turn the dimmer up to full brightness.
John Strenk is offline
post #24 of 35 Old 12-31-2012, 02:14 AM
only in a jeep cj
Close, but the intermittent wiper for the CJ was 1984 on as the dash harness is wired different to accept the 4 wire wiper motor which uses a different switch ( and a second option of the intermittent switch/ harness) I had about 10 CJ dash harness out at one time from 75 to 86, and when comparing the fuse boxes, plugs, and other year to year changes, I saw all the pre 84s did not come with intermittent wipers.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #25 of 35 Old 12-31-2012, 04:40 AM
John Strenk
1976 CJ5
Wow, do you still have all those harnesses?
it would be great to take pictures of each connector for each year.
post #26 of 35 Old 12-31-2012, 06:01 AM
PROJECT 23
Thanks Kieth!
If you can get the glove box door, I have an extra lock and key.
post #27 of 35 Old 12-31-2012, 06:28 AM
John Strenk
1976 CJ5
I've got a black door that says "Loredo" on it. It's a little scratched up but you can have it if you pick it up.
post #28 of 35 Old 12-31-2012, 07:59 AM
Destr0
What color wire off of the headlight switch would I wire to my new mirror to have the lights come on when you click the instrument dimmer all the way on?
When I wired it up I ran a third wire but it currently is just coiled up under the dash.
Thanks!
PS>> I do have a factory service manual but it is on my desk at work and I will not be back for several days and want to do this wiring while I have my down time.
~Kevin
1994 Jeep YJ off road toy
1981 CJ7 SBC 350
2005 KJ Libertyt 4x4 CRD w/ 2.5" Frankenlift DD
Destr0 is offline
post #29 of 35 Old 12-31-2012, 08:26 AM
John Strenk
1976 CJ5
Got a schematic of the mirror?
Basically you will have to run a constant hot to the light in the mirror and then the ground wire from the mirror will run to the ground lug on the Headlight switch.
If your mirror does not have a separate ground, then you would have to use a relay to switch it with the headlight switch.
post #30 of 35 Old 12-31-2012, 09:59 AM
Destr0
I will have to figure out some other way to make it work then- I wonder if I can use a relay and use that ground off the switch to trigger the relay?
The mirror has three wires: Red (switched 12V for the courtesy lamp function), Orange (constant 12V for the map light switches on the mirror) and a ground wire. I already have the orange and black wires ran and the light is working fine off of the switches on the mirror, I just figured a "dome light" function off of the headlight switch would be cool.
1981 CJ7 SBC 350
Destr0 is offline
Dash lights.! MHSJEEPKID2012 Jeep CJ Forum 3 10-15-2009 03:07 PM
Courtesy Lights Have Me Stumped Balvar24 Jeep CJ Forum 12 04-15-2009 12:35 PM
dash lights and head lights "pulse" slightly CrazyHorse6 Jeep CJ Forum 17 02-16-2009 01:20 PM
no brake lights and no dash lights boydog40 Jeep CJ Forum 6 03-01-2006 06:49 PM
dash lights out! help!! edge1 Jeep CJ Forum 14 10-17-2004 10:36 PM
