Dome/Courtesy/Under Dash Lights. - JeepForum.com
post #1 of 35 Old 11-12-2009, 08:17 AM Thread Starter
Group_er
well Ive started dilivering pizza in my jeep last night, and all went pretty good except! No Interior Lights!!!!!!!!!
I have the door switches, and the under dash factory courtesy lights, I just have to install, and wire them, but Im running a softtop, and dont have a dome light. I have a full cage to weld into the jeep in the future. When that goes into i will make a above console with buit in leds, But for now!
I was wondering what some of you guy have done for over head courtesy light in your CJ'S? (pics are great!!)
Of even pics of over head consoles would be nice for the future, I wonder if a TJ console would fit my cage.....hmmmmmm
Thanks for any pics everyone!
Group_er is offline
post #2 of 35 Old 11-12-2009, 08:41 AM
1984CJ
1984CJ's Avatar
Midwest Specialties RB-1 - Roll Bar Dome Light - Quadratec
This is the most common that I have seen however some people have retrofitted rear view mirrors, that have interior light, from other vehicles into the CJ
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline
post #3 of 35 Old 11-12-2009, 08:56 AM
Jeepican
1976 CJ5
You can get it at 4wd.com or others for like $20 Sport Bar Dome Light and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #4 of 35 Old 11-12-2009, 08:57 AM
Jeepican
1976 CJ5
Ha just realized that was the same light..... oh well ....
-Barney Fife-
Jeepican is offline
post #5 of 35 Old 11-12-2009, 10:03 AM
gmgreen
1983 CJ7
That's the one I have and it works great.
gmgreen is offline
post #6 of 35 Old 11-12-2009, 10:12 AM
Johnnylaw
I have this installed, love it.
CIPA 36000 - Interior Rear View Mirror with Maplights for 76-06 Jeep® CJ & Wrangler YJ & TJ - Quadratec
Johnnylaw is offline
post #7 of 35 Old 12-25-2012, 10:19 PM
wishfulthinking
1982 CJ7
Originally Posted by Johnnylaw
I just got the map light mirror and was wondering how you have the wiring from the mirror to the fuse box. Any pics would be great.
wishfulthinking is offline
post #8 of 35 Old 12-25-2012, 10:42 PM
Destr0
I picked up a mirror from the junkyard just last week and installed it. The mirror I got has map lights, ir only has three wires: Ground, power from battery and power from door switches. As I don't yet have any door switches, I have mine wired just for the two on/off switches on the mirror itself.
Don't remember what I pulled it from- but I was in the Chevy section of the junkyard. Cost me $2.99 at the U-Pull it yard.
As I don't have any door switches or any under dash lighting at all in my CJ it is a vast improvement. I am planning on wiring up the door switch and "dome" light function of the mirror- I ran a wire for it when I put it in but it is currently just coiled up under the dash and not connected ot anything.
1994 Jeep YJ off road toy
1981 CJ7 SBC 350
2005 KJ Libertyt 4x4 CRD w/ 2.5" Frankenlift DD
Destr0 is offline
post #9 of 35 Old 12-25-2012, 10:46 PM
only in a jeep cj
The only mirrors that fit between the visors are the 8 inch versions and aren't those lighted ones wider? More like 10". So are you just not using visors?
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #10 of 35 Old 12-25-2012, 11:02 PM
Destr0
Swapped left to right the sun visors clear the lighted mirror just fine. :-)
1981 CJ7 SBC 350
Destr0 is offline
post #11 of 35 Old 12-26-2012, 07:11 AM
CJunk
Just get a 5 dollar push button battery powered led light (walmart). They have a sticker on the back, or put a magnet on it and stick it wherever you like. Cheap,no wiring, and you have a small flashlight if you need one.
CJunk is offline
post #12 of 35 Old 12-28-2012, 12:46 AM
jumbojeepman
1976 CJ7
I occasionally use my Jeep to deliver when it snows (although I normally use my F-250 because it's warmer.) I agree the lack of a overhead light is annoying, especially since whatever light you improvise with you have to turn on and off.
jumbojeepman is offline
post #13 of 35 Old 12-29-2012, 08:39 AM
gronked
I bought the above item, removed the spring and "magnet" side of the clip, filed off the ears and screwed it to the windshield top. The plastic of the CA (California Acc.) brand is soft plastic, and won't crack when screwed. It is bright, swivels, and best of all, follows the K.I.S.S. logic.
gronked is offline
post #14 of 35 Old 12-29-2012, 08:54 AM
wellmax
i have a 1984 model cj7 base model, i do not think my jeep ever had anythinglike those lights you are talking about.
the hardtop does have an imprint of a dome light that was attached at sometime in the past.
why not just buy a stick on light with batterys and use it. you just touchthe light and it comes on/off
quick and easy, use it when needed and not worry with your jeep wiringsystem which is limited at best.
good luck,
http://www.amazon.com/gp/product/B0046KIABG/ref=pd_lpo_k2_dp_sr_3?pf_rd_p=486539851&pf_rd_s=lp o-top-stripe-1&pf_rd_t=201&pf_rd_i=B0056B58AU&pf_rd_m=ATVPDKIKX 0DER&pf_rd_r=1DMNYF04RC21A0JW4SS4
wellmax is offline
post #15 of 35 Old 12-30-2012, 12:55 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
My only issue with the battery powered lights is winter time - the cold and AAA batteries (or even AA size) don't get along, so I quit using them. I like the idea of the rear view mirror. I know Sebring convertibles had them, used LED lights on the bottom of the mirror. I'd wire the door switch circuit to the headlight switch's dome light ckt, and then if you need the light, just turn on the switch. This way no hassle of door switches (CJ's even have door switches??) for when you remove the doors.
Rick
Cutlass327 is offline
Dash lights.! MHSJEEPKID2012 Jeep CJ Forum 3 10-15-2009 03:07 PM
Courtesy Lights Have Me Stumped Balvar24 Jeep CJ Forum 12 04-15-2009 12:35 PM
dash lights and head lights "pulse" slightly CrazyHorse6 Jeep CJ Forum 17 02-16-2009 01:20 PM
no brake lights and no dash lights boydog40 Jeep CJ Forum 6 03-01-2006 06:49 PM
dash lights out! help!! edge1 Jeep CJ Forum 14 10-17-2004 10:36 PM
