Does it matter what brand driveshaft I get? - JeepForum.com
post #1 of 6 Old 01-26-2010, 08:11 PM Thread Starter
MSBXCJ
1982 CJ7
I bent my front drive shaft pretty bad and I need to purchase a new one. I have a 258 I6 engine with a T5 transmission. I want to try to spend the least amount possible while still keeping in thought that I sometimes take my Jeep to the 4 wheel drive park and go on mainly the 2,3,and 4 grade trails. It isnt a daily driver so I dont think I need anything super strong/expensive...however I might be wrong......what do yall think? Also, any idea on how expensive it would be to buy the part and have someone install it for me?
Thanks
MSBXCJ is offline
post #2 of 6 Old 01-26-2010, 08:32 PM
halpeters
1978 CJ7
Why not repair your bent drive shaft. The Shaft portion can be easly replaced by any local "driveline shop" for less than the cost of new - they cut the welds to reuse the yokes, and weld in a new shaft.
Removing and re-installing the drive shaft is really a simple job that can be done in your driveway.
This should be much cheaper than buying a driveshaft, and is a good skill to have...
Hal
1978 CJ-7
halpeters is offline
post #3 of 6 Old 01-26-2010, 08:50 PM
mmerlina
Image Glassworks, Inc.
mmerlina's Avatar
Repairing your current one sounds like a good idea to me.
However if you are hellbent on going for a new one.. give this guy out in UT a call.. eBay Store - DRIVESHAFT: JEEP, SYE, DRIVE SHAFT
He's a real nice guy to talk to, he's not in it to become a millionaire, he's just trying to support his offroading addiction like the rest of us.
I got a rear CV shaft made up and the quality was exceptional, and from what I understand he's cheaper than TW. A couple guys in my club also have his stuff.
Good luck either way.
Mike
1986 Jeep CJ7 (
Remanufactured 258, ARB lockers front & rear, 4.10 Yukon gears, 35x12.5" Super Swamper SSR's, Motorcraft 2100, 4.5" Rubicon Express Extreme-Duty lift, York 210 OBA, Big Daddy steering, Tatton rear CV driveshaft, Herculined interior, TJ flares, lots of body & upholstery work
mmerlina is offline
post #4 of 6 Old 01-26-2010, 09:16 PM
NelsonATC
1980 CJ7
x2. Just got my Tatton's last week. Still weeks away from running them, but the quality of his work is top notch
Mike
1980 CJ7
NelsonATC is offline
post #5 of 6 Old 01-27-2010, 09:56 AM Thread Starter
MSBXCJ
1982 CJ7
I didn't know you could re-tube a drive shaft, cool. Thanks for the idea, I'll start calling around
MSBXCJ is offline
post #6 of 6 Old 01-27-2010, 10:13 AM
jds79cj
You drive shaft is going to have slip center so it may not be as easy to repair as previousliy posted but it still should be able to be repaired cheaper then if you purchased a new one.
jds79cj is offline
XJ Front driveshaft used as a rear driveshaft CJ5911 Jeep CJ Forum 24 11-02-2012 08:17 PM
HELP- Adding Hydroboost - ABS matter? DuggerCJ Jeep CJ Forum 0 08-31-2009 09:39 PM
What brand??? mherois Jeep CJ Forum 8 05-24-2008 11:46 PM
Brand Spankin New! NTheMountains Jeep CJ Forum 3 06-14-2005 06:53 PM
Guess it was just a matter of time Skitz Jeep CJ Forum 21 01-24-2004 09:43 AM
