Does this look right - JeepForum.com
post #1 of 5 Old 06-06-2014, 03:37 PM Thread Starter
Tfain
1978 CJ5
Tying to figure out why my speedo doesn't work today. I took the cable off and did the drill test and it worked fine so I took the speedo gear out of the t-case thinking that would be broken. It looks fine to me but thought I would post a pic and ask you guys and see if this is ok what to check for next
Tfain is offline
post #2 of 5 Old 06-06-2014, 04:37 PM Thread Starter
Tfain
1978 CJ5
I found the problem. Not sure what the solution is though. If I tighten the speedo cable all the way it won't work. I have it only on half way right now and it works fine now. Could the cable be to long?
Tfain is offline
post #3 of 5 Old 06-06-2014, 06:01 PM
strvger01
1966 CJ5
don't know about the length, but you could just thread it on half way using lock-tite to keep it there.
good luck to you.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #4 of 5 Old 06-06-2014, 07:28 PM
Mike Romain
Lol! 100% for sure, it just happened to another gent on a thread here today. The cores are universal replacements you cut to size, he just cut 1/4" off his and it works.
Mike
Mike Romain is offline
post #5 of 5 Old 06-06-2014, 08:45 PM Thread Starter
Tfain
1978 CJ5
I just cut mine today and it works fine now. Well as good as a 36 year old gauge is going to work. I could tell it was a new cable the PO put in I just never put one in before so didn't know you had to cut them
Tfain is offline
