Does this Holley idle linkage look correct? - JeepForum.com
post #1 of 18 Old 05-24-2013, 06:19 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Tried setting my idle speed last night and with the vac advance disconnected could not get the idle below 1000rpm.
Turned the idle screw all the way out until it was no longer touching. Wondering now if there is a linkage or spring hooked up incorrectly.
The following pics show how the linkage and springs are hooked up.
Thanks in advance!
2X
2Xtreme is offline
post #2 of 18 Old 05-24-2013, 06:36 AM
Ivehad4
1978 CJ7
One thing to check is the adjustment of the accelerator pump linkage. It could be juicing the carb. at idle if its set up too tight. My Holley is different but the instructions call to check it WOT with a feeler gage. For starters make sure its not engaged at all at idle condition.
1978 CJ7 304/T150
1959 Willys CJ5 F4/T90
1995 XJ 4.0
1998 TJ 4.0
Ivehad4 is offline
post #3 of 18 Old 05-24-2013, 06:45 AM
ksk1480
Check you idle mixture screws. Adjust those first for a good mixture at idle then the speed screw.
ksk1480 is offline
post #4 of 18 Old 05-24-2013, 07:04 AM
swatson454
1983 CJ7
Stupid question here: did you plug the vacuum line? Hey, it happens...
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #5 of 18 Old 05-24-2013, 07:07 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Stupid me: Nope!
Plugged the vac advance at distributor.
Left vac line open.
No Bueno, huh?
2Xtreme is offline
post #6 of 18 Old 05-24-2013, 07:14 AM
swatson454
1983 CJ7
Originally Posted by 2Xtreme View Post
Stupid me: Nope!
Left vac line open.
No Bueno, huh?
Been there, done that
Plug the nipple at the carb or leave the line plugged into the carb and plug the dizzy end of the hose with a screw or something.
Shawn
post #7 of 18 Old 05-24-2013, 07:20 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
>>PHEW<<
Simple fix!
Thanks!
2X
2Xtreme is offline
post #8 of 18 Old 05-24-2013, 08:15 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
OK, just to be sure I am clear....
I have to have the (manifold) vacuum line disconnected from the distributor and the port on the distributor plugged.
AND
Plug the (manifold) vacuum line that came off of the distributor...
Correct?
2Xtreme is offline
post #9 of 18 Old 05-24-2013, 08:27 AM
swatson454
1983 CJ7
You don't have to plug the distributor, just the line.
I usually just pull the line off of the distributor and thread a screw into the end of it (the end of the hose that you pulled off of the distributor).
Savvy?
post #10 of 18 Old 05-24-2013, 08:29 AM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Savvy
2Xtreme is offline
post #11 of 18 Old 05-24-2013, 10:08 AM
Jack61
1981 CJ7
Vacuum line's need to be hooked up to set idle. Check that your linkage has enough travel, secondary's are closing all the way, that the spacer and gaskets are not interfering with the throttle plates, and that the spacer and gaskets are fully sealing the base of the carb which if they are not would cause a vacuum leak and high idle.
It used to be, God bless America, it has become God help America
Jack61 is offline
post #12 of 18 Old 05-24-2013, 10:20 AM
duffer
1955 CJ3B
2x and the adjustment screw is on the bottom of the flange (carb needs removed to get at it).
1955 CJ 3B, 381cid sbc (441cid all aluminum sbc coming soon), AGE M22W, Teralows, Warn OD, OBA, Premier Power welder, Warn 8274
1968 CJ 5, factory 225" w/ headers/450 cfm Holley, T86AA, Belleview winch, Warn OD
2012 Wrangler Rubicon Unlimited, Warn 9.5 xp-s winch
duffer is offline
post #13 of 18 Old 05-24-2013, 01:57 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
Vacuum line's need to be hooked up to set idle......
Is t this the opposite of what Shawn said?
Wheel, Fix, repeatů.
2Xtreme is offline
post #14 of 18 Old 05-24-2013, 03:11 PM
Jack61
1981 CJ7
If you leave the vacuum advance line off especially when using manifold vacuum for the advance it will raise the idle by several hundred rpm's when it is reconnected. Only time to disconnect the vacuum advance line is when setting initial timing.
Jack61 is offline
post #15 of 18 Old 05-24-2013, 03:28 PM
swatson454
1983 CJ7
X2
Set timing with no vacuum and make all carb adjustments with everything hooked back up.
Shawn
