Does everyones disc brakes do this? - JeepForum.com
post #1 of 6 Old 07-16-2003, 08:49 AM Thread Starter
BART CJ5
BART CJ5's Avatar
1979 CJ5
My pads rattle terrible. I just repalced with new pads and not enough of a change to satisfy me. These do not have clips like later model disc brakes. Any suggestions.
BART CJ5 is offline
post #2 of 6 Old 07-16-2003, 10:15 AM
only in a jeep cj
Make sure the piston moves freely in the bore of the caliper and grease the grooves and "tabs" that the caliper rest in the knuckle mount as it sound like it isn't adjusting to the movement and leaving too large a gap.....then the rotors vibrate the pads...
just a guess
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #3 of 6 Old 07-16-2003, 11:18 AM Thread Starter
BART CJ5
BART CJ5's Avatar
1979 CJ5
My right piston boot has a little tear in it and it isn't perfect but, the other side moves freely. The caliper was pretty rusty before I worked on them and now are greased and the rust removed. They move free'er now but still probabley aren't quite right yet.
Thanks, Only in a jeep cj.
BART CJ5 is offline
post #4 of 6 Old 07-16-2003, 11:21 AM
MudLover
MudLover's Avatar
Could your rotors be the problem? I doubt they are, but do they looked warped in anyway?
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
Red Jeep Club Member #2
MudLover is offline
post #5 of 6 Old 07-16-2003, 11:29 AM Thread Starter
BART CJ5
BART CJ5's Avatar
1979 CJ5
I didn't turn them. I just deglazed them. They didn't have any high spots or discoloring. I think there true. They aren't grabby when stopping either.
BART CJ5 is offline
post #6 of 6 Old 07-16-2003, 12:51 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Wink
I'm not sure of what type of adjustments can be made to your brakes, but IIRC about brakes in general, the pad should not contact the rotor all at once, or perfectly flat, if you can visualize what I mean.
I think on "tip" of the pad, likely the top?, should touch first by a hair, it's kind of like the pads have some toe-in.
Having the pads at a SLIGHT angle to the rotor on first contact make a huge difference, for example, on a bicycle wheel.
I could be way off, I've never had to do anything more than swap pads myself, and mine had no problems.
Just a shot in the dark.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
disc brakes Rivcamp Jeep CJ Forum 3 11-19-2007 08:10 AM
83 CJ7 with Disc Brakes lopezzi Jeep CJ Forum 2 11-18-2007 11:26 PM
73 with 78 disc. brakes??? fl-jeep Jeep CJ Forum 8 10-25-2007 06:51 PM
Disc Brakes? FILDO Jeep CJ Forum 9 07-14-2007 02:06 PM
Disc brakes on a 73 CJ5? Gumy Jeep CJ Forum 4 12-30-2006 06:59 PM
