Does a Dana 30 or a 44 use a pinion crush sleeve? - JeepForum.com
post #1 of 14 Old 02-28-2009, 11:18 AM Thread Starter
imtheant
As I am in the process of helping my buddy regear my Dana 30 and 44, I didnt see anywhere in the rebuild kits or in the back of the quadratec catalog a replacement crush sleeve that goes on the pinion. I thought all axles used these and was necessary for the correct preload. Can someone point me in the right direction?
1983 CJ7 - Project "Surf Jeep Restoration"
imtheant is offline
post #2 of 14 Old 02-28-2009, 11:24 AM
gojeepin
1983 CJ7
Unless I'm mistaken, they both use shims for pinion preload.
p.s. On today's episode of Extreme 4X4, Ian was installing new gears and a locker in a Dana 44.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 14 Old 02-28-2009, 11:41 AM
Coiz
1979 CJ7
I thought the same thing but the master rebuild kit they sell at Morris 4x4 does have a crush sleeve listed as one of the parts for a 1986 and up Dana 44 although I don't see one in the exploded picture of the axle. The Dana 30 parts and picture clearly shows it is shimmed and lists no crush sleeve.
Someone on here had a link to axle identification and factory rebuild instructions. I thought I bookmarked it but can't find it for the life of me.
Morris 4x4 master rebuilt kit description for a Dana 44:
1986 JEEP CJ7 & CJ8 SCRAMBLER MASTER BEARING ,SEAL & HARDWARE KIT W/DANA 44 REAR Axle kit Includes: Pinion,carrier bearings,crush sleeve,oil seals,cover gasket,Axle shaft inner/outer seals and bearings.
Like I said, I don't see it in the picture.
Edit, if you click on #30 it lists it for 70-75 Dana 44 and does not have a crush sleeve listed. #8 is for 1986 and up and does list the crush sleeve. Think it's a typo?
Do either of the axles your taking apart have crush sleeves already in them?
Mike
Coiz is offline
post #4 of 14 Old 02-28-2009, 01:04 PM
foggybottombob
There ya go. If you did not take one out then you don't put one back in. I think the TJ dana 30 uses a crush sleeve but the high pinion D30 and the CJ style long pinion D30 do not. I have not seen a D44 that uses a crush sleeve but I have not worked on one of the newer ones like a Rubicon. So I don't know what the new ones have in them.
foggybottombob is offline
post #5 of 14 Old 02-28-2009, 01:19 PM Thread Starter
imtheant
Thanks guys. I just watched them do a regear on a Dana 44 on extreme 4x4 this afternoon and they specificaly said the 44 uses NO crush sleeve, just shims.
imtheant is offline
post #6 of 14 Old 01-22-2010, 01:01 PM
mike149
2009 JK Wrangler
Crush Sleeve
I have a 2009 4 Door Rubi and the front dana 44 has a crush sleeve. Mopar 1-05066047aa
2009 Rubicon Unlimited, Dana 60 Front & Rear Axles, 538 Gears, Rubicrawler, Monster Brakes, Monster Master Cylinder, ARB Lockers Front & Rear, 40x16.50 Pitbull Bias Tires, Stazworks Double Beadlock Wheels, Max Steel Extended Rock Sliders, PSC Hyd Steering, Complete Under Body Armor, Smittybilt XRC Armor Fenders Front & Rear, Mopar Half Doors.
mike149 is offline
post #7 of 14 Old 01-22-2010, 02:41 PM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
The wrangler 30/44 use crush sleeves, the CJs use shims.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #8 of 14 Old 01-22-2010, 05:20 PM
_Kyle_
_Kyle_'s Avatar
The newer XJ and ZJ 30s use crush sleeves too.
So without a crush sleeve, I could remove my yoke to replace the seal without worrying, right? (sorry to derail the thread).
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #9 of 14 Old 05-31-2011, 12:45 AM
kliff53
The Hi Pinion 30, '94 XJ uses NO crush sleeve, shims only. Got one torn apart on the work bench right now...NO CS. Master rebuild kit from ECG, NO crush sleeve eith, only shims.
kliff
kliff53 is offline
post #10 of 14 Old 05-31-2011, 01:29 AM
bandhmo2
The original, IE older Dana 30 and 44 used shims not a crush sleeve. Many if not all of the new ones do use a crush sleeve. So it depends on year.
The crush sleeve is easier to setup both at the factory and when regearing. Some say the crush sleeve can crush if the pinion takes a strong hit off road, but I find it hard to believe as the hit would have to be pulling the pinion out of the differential for that to happen, a hit that had would likely break other things as well.
So you simply need to get the correct kit for your year. If these are CJ axles then no crush sleeve.
bandhmo2 is offline
post #11 of 14 Old 05-31-2011, 04:21 AM
5-90
5-90's Avatar
1988 XJ Cherokee
I think all D44s used shims - some D30s used crush sleeves. Got a BoM number? I'm working with Dana lists for the next couple of days or so - gimme application and BoM, and I can confirm.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #12 of 14 Old 05-31-2011, 06:12 AM
Patter
1981 CJ5
Originally Posted by bandhmo2 View Post
the original, ie older dana 30 and 44 used shims not a crush sleeve. Many if not all of the new ones do use a crush sleeve. So it depends on year.
The crush sleeve is easier to setup both at the factory and when regearing. Some say the crush sleeve can crush if the pinion takes a strong hit off road, but i find it hard to believe as the hit would have to be pulling the pinion out of the differential for that to happen, a hit that had would likely break other things as well.
So you simply need to get the correct kit for your year. If these are cj axles then no crush sleeve.
x2.
"I have a very strict gun control policy: if there's a gun around, I want to be in control of it."
Patter is offline
post #13 of 14 Old 05-31-2011, 06:16 AM
foggybottombob
I don't know why this was dug up from the archives but this is what I know about it.
TJ and ZJ low pinion Dana 30's use a crush sleeve. There are short pinion and long pinion versions of these.
Isuzu Rodeo and Honda Passport Dana 44's use a crush sleeve.
All other Dana 30s and 44s I am aware of use pinion pre-load shims.
post #14 of 14 Old 05-31-2011, 06:40 AM
Patter
1981 CJ5
Wow Foggy. I didn't even catch the old posts. I even knew that "imtheant" hasn't been here for a while.
Broke my thumb last week. Blaming this senior moment on the medication.
Patter is offline
dana 30 low pinion(cj) want to convert to dana 30 hi pinion(xj) white_cj Jeep CJ Forum 5 12-02-2009 05:41 AM
dana 30 pinion snubber pathfinder Jeep CJ Forum 1 11-26-2009 10:11 AM
can i just use a crush sleeve in my cj dana 30? 26679cj5 Jeep CJ Forum 4 06-14-2009 10:01 PM
AMC 20 Pinion Seal reassembly: What crush washer?? hfjeff Jeep CJ Forum 22 03-26-2007 04:58 AM
Dana 30 Ring and Pinion Crush Sleeve Wiggy Jeep CJ Forum 2 01-30-2005 01:30 PM
