Does CJ7 with power brakes have brake pedal return spring? - JeepForum.com
post #1 of 7 Old 05-11-2014, 11:22 PM Thread Starter
calvykins
Hi everyone.
This has been posted before but there wasn't a definitive answer
I have a 1982 CJ7 with power brakes. There is no brake pedal return spring fitted.
The workshop manual and some photos on the internet show the spring but some people suggest that the spring is not necessary with power brakes.
Does anyone know which is correct?
Thanks
calvykins is offline
post #2 of 7 Old 05-12-2014, 05:31 AM
Mike Romain
Mine does.
Mike
Mike Romain is offline
post #3 of 7 Old 05-12-2014, 08:39 AM
CSP
Every brake pedal has a return spring. Doesn't matter if it's power or manual.
CSP is offline
post #4 of 7 Old 05-12-2014, 08:45 AM
1949er
Power Brake unit has a internal spring
1949er is offline
post #5 of 7 Old 05-12-2014, 12:07 PM Thread Starter
calvykins
Thanks 1949er I think you might be right
I've just reassembled the pedals and power brake unit and it seems that the spring is not necessary as the internal spring in the power unit pushes the pedal so that it is exactly in line with the clutch pedal. It returns to the same place aligned when pushed
post #6 of 7 Old 05-12-2014, 12:27 PM Thread Starter
calvykins
Here's a pic of the aligned pedals without a spring.
post #7 of 7 Old 05-12-2014, 12:49 PM
Spieg8
1984 CJ8
I had to put one on my '84 (not sure there was one that broke/fell off or not... but there was a place for it). Without it, the pedal wouldn't return enough to trigger the brake light switch (my brake light would stay on most of the time).
Spieg8 is offline
brake
