does the 86 cj7 have external volt-reg - JeepForum.com
post #1 of 2 Old 06-27-2003, 10:05 AM Thread Starter
rusty86cj7
Or is it built into the alternator. I just replaced the Alternator but the additional draw from lights and accessories sometimes makes the volts dip to near discharge. Want to know what to replace next or to replace the Alternator again.
Dale aka rusty86cj7
rusty86cj7 is offline
post #2 of 2 Old 06-27-2003, 11:00 AM
dana60cj
dana60cj's Avatar
It's an internal voltage regulator, unless some non stock one was put in there. I ran into this when trying to hook up a welder in My Jeep a while back.
Last time I swapped mine, I had trouble lining up the plug that enters the alt. Once I got both of the prongs on it was fine, before that the new alt. didn't seem to fix the problem of low voltage.
Other things:
Check battery
Check alternator again
All wiring is hooked up correctly, not corroded, and has all of it's insulation.
Belt is tight on alternator
Best of luck
'84 CJ-7, 6" lift, 33" BFG's, I6, .030 Over, Comp Cam, 400cfm Weber, K&N, T-18, 4 Core, Snorkel, D60 Detroit, Custom CV Driveshaft, 1350 U-Joints, D30 True Trac, Alloy shafts, S.R.S. w/ buggy springs, Custom Folding Shackles and Spring Hinges, Custum Tire Rack, Designed On Board Air, Optima's. Sneaky Jeep Owner #3.
dana60cj is offline
Do I need volt gauge? Bubba Ray Jeep CJ Forum 9 09-22-2008 03:19 PM
24 volt winch in a CJ supraman1990 Jeep CJ Forum 5 06-11-2008 10:13 AM
volt probs? moach1 Jeep CJ Forum 2 10-06-2006 08:57 PM
Volt reading went down to 11 dtrimble Jeep CJ Forum 2 01-07-2005 06:59 PM
6 volt or 12 volt?????? Foshigity2017 Jeep CJ Forum 3 11-02-2004 12:58 PM
