Do It Your Self Bedliner - JeepForum.com
post #1 of 16 Old 11-03-2003, 11:40 AM Thread Starter
tico
I've been thinking about doing a roll on bedliner in my cj5 tub anybody out there have any suggestions about different brands application proccesses ect... .I really don't want to do the line-x or rhino I have the tub all striped out and ready to go. I've been looking at herculiner anyone have any experience with that stuff. Any info would be appreciated. Thanx
tico is offline
post #2 of 16 Old 11-03-2003, 03:15 PM
bernie
I have heard stay away from the cheap versions.
I heard Herculiner is good;
I built my own steel hard top and used Herculiner on it--
I'm impressed, the stuff was easy to apply, and it is very tough.
Follow the directions; definitely get the xylol for cleanup (per directions).
I will use it again--got some floorboards, etc to do.
Don't start the revolution without me...
bernie is offline
post #3 of 16 Old 11-03-2003, 03:46 PM
jadams68
jadams68's Avatar
I'm using herculiner either this weekend or next depending on time.
What I do know is that a spayed on application of bedliners is far superior in quality than just rolling it on.
Here's a great write-up.
Herculine your tub
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #4 of 16 Old 11-03-2003, 05:15 PM
johny1i
johny1i's Avatar
I applied black Herculiner to my tub a few months ago and love it. The prep work was a royal PITA (mainly because I'm too anal), but I'm glad I spent the time grinding all of that rust and treating it all with Navel Jelly now. Some of the guys I work with have Rhinoliner in the beds of their trucks, but I actually prefer Herculiner because of the semi-gloss black finish, versus the flat gray finish of their Rhinolinings. Unfortunately, it does get pretty dulled where you're feet are with time, but I've found that semi-gloss black Rustoleum is practically a dead-ringer, so I bet it could always be touched up if you really cared about that sort of thing.
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
post #5 of 16 Old 11-03-2003, 07:20 PM
mad_matt
I Herculined my tub last spring. I love it. I have worn through right under my removable sterio consol but Im hard with it. I would do it again. for what it's worth.
'76 cj-7 on 35's
"What the hell do you mean they don't make banjo bolts anymore?!"
mad_matt is offline
post #6 of 16 Old 11-03-2003, 07:36 PM Thread Starter
tico
Herculine your tub
what type of spray gun thanks for the reply
tico is offline
post #7 of 16 Old 11-03-2003, 07:37 PM Thread Starter
tico
did you spray it on or roll it on. Thanks for the reply
tico is offline
post #8 of 16 Old 11-04-2003, 11:18 AM
homerscj7
homerscj7's Avatar
I rolled the cheapo Rustoleum bedliner stuff on the floors of my XJ. It's been abused for about 6 months now and holding up great for $20/kit.
Good prep work is a must though, get rid of all the rust and clean it with Xylene.
The road to destruction is paved with good intentions
homerscj7 is offline
post #9 of 16 Old 11-04-2003, 12:57 PM
mad_matt
Where do you get that? It sounds like it's right up my alley$
'76 cj-7 on 35's
mad_matt is offline
post #10 of 16 Old 11-04-2003, 01:04 PM
MudLover
MudLover's Avatar
The PO of my CJ7 did a roll on bed liner. It's ok, but I spilt brake fluid on part of it and it sat there for a day. The bed liner started to peel after that. I dunno what brand it was, but I didn't like the idea that it wouldn't hold up to brake fluid.
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
Red Jeep Club Member #2
MudLover is offline
post #11 of 16 Old 11-04-2003, 01:22 PM
homerscj7
homerscj7's Avatar
Ollie's Bargain Outlet and last I knew every store in this area was out of it. There are other places but it might be $24/kit. I'll have to look at the boxes for the name of the kit and look it up on Google. I know there's an online dealer.
post #12 of 16 Old 11-04-2003, 02:26 PM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
Did mine with herculiner a couple of weeks back.
Prep is key, but I rolled it and painted it on, it is looking good
http://f1.pg.photos.yahoo.com/ph/cb4...28.jpg&.view=t
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #13 of 16 Old 11-04-2003, 03:41 PM
oreo_n2
whats so special about using xylene over mineral spirits or turpentine or otherr solvents?
Brent
1983 CJ7
oreo_n2 is offline
post #14 of 16 Old 11-04-2003, 05:43 PM
johny1i
johny1i's Avatar
The kit I used came from Autozone because they had a $20 rebate deal going on which brought the total to $80, and that included a 4" roller. I wound up buying a better roller because that one was a POS, but I rolled two full coats on thick, covering all the way up under the dash as high as I could get and up the sides of the interior to the underside of the top lip, and still had about 1/5 of the gallon left over. There are a few drips if you look close, but overall it's pretty uniform.
johny1i is offline
post #15 of 16 Old 11-05-2003, 10:37 AM
40Below
40Below's Avatar
I too Herc-ed my CJ and as the others have said it is all in the prep. As for the question on the xylene, it is a MUST have to cut the bonding agents. I bought a gallon and have over half of it left. wipe down the area you are going to line at least 3 times with a new rag each time.
I found that the Herc is not as durable as the commercial line-x in my P/U but for a jeep it is just fine, I dont plan on hauling rocks and gravel in the Jeep bed.
I rolled my liner on with a brush for the corners. I even did a "over the rail" liner to protect the tub where the hard top sits. I used the plastic masking tape for stucco to mask ofF the area and it worked great. DONT USE PAPER TAPE TO MASK THE EDGE, it will have to be cut out to remove it the chemicles in the liner seap through it real fast.
84 CJ7 Laredo 258/T5 herced tub 86/D44 4.5"RE lift, 33Xterrains and a TWoods CV driveshaft Custom bumpers and tire rack.Blue Jeep Club #140
40Below is offline
Spray in bedliner > You Do It turpehar Jeep CJ Forum 351 07-06-2016 04:44 PM
Bedliner on wheels..... starfire340 Jeep CJ Forum 4 03-05-2008 02:25 PM
Anyone know about Onyx bedliner? Collard Green Jeep CJ Forum 0 02-22-2008 09:57 AM
U-Pol Raptor Bedliner cj71983 Jeep CJ Forum 0 02-19-2008 11:15 AM
What do you use the bedliner for? jeepmor Jeep CJ Forum 1 10-17-2006 07:35 AM
