Do you / are you suposed to change soft brake lines with SOA Lift? - JeepForum.com
post #1 of 7 Old 10-08-2011, 05:40 AM Thread Starter
offroadrider
1965 CJ5
Hi, my jeep came with a torn driver side front soft line. It has spring over axle lift, is it suppose to have different lines?
offroadrider is offline
post #2 of 7 Old 10-08-2011, 05:59 AM
nshefbuch
1982 CJ7
You would want them longer. The added flex from SOA will stretch and rip a stock one. As for material makes no difference if the line is rubber hard or braided. I make small extensions from frame to rubber line. Cheap and easy fix
CJ7/SOA YJ leaf/5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt/d44 ARB 4.10 High Steer
nshefbuch is offline
post #3 of 7 Old 10-08-2011, 03:41 PM
skizriz
1978 CJ7
Front hoses from a late 80's full size Chevy truck work nice. They are 10" or so longer.
You only need to re-drill the hole where they mount to the caliper to 7/16. Make sure to also pick up 7/16 copper washers for them.
They are about $15 each.
skizriz is offline
post #4 of 7 Old 10-20-2011, 05:01 PM Thread Starter
offroadrider
1965 CJ5
I have a 1965 cj with drums, willl this work?
post #5 of 7 Old 10-20-2011, 05:15 PM
skizriz
1978 CJ7
The fitting that goes into your drum would be different.
Maybe an older pickup with drum brakes might work.
skizriz is offline
post #6 of 7 Old 10-20-2011, 06:11 PM
gojeepin
1983 CJ7
It's really a matter of distance and not whether it's spring over or spring under.
If you can't find stock lines from another vehicle that'll work, there are shops in most areas that will build custom lines.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #7 of 7 Old 10-20-2011, 07:46 PM
nshefbuch
1982 CJ7
I had a 62 with drums and what I did is ordered two stainless ones and used couplers to joint them with the stock rubber lines for twice the length and it worked just fine for years.
Will I need extended brake lines for a 2.5" lift? SD84CJ7 Jeep CJ Forum 4 09-26-2009 08:01 PM
New Brake Lines 3" Lift nazdackster Jeep CJ Forum 5 03-14-2009 03:29 PM
RE lift brake lines hammode Jeep CJ Forum 2 03-12-2008 04:01 PM
44" lift, extended brake lines? dragracer1199 Jeep CJ Forum 2 01-31-2008 01:33 AM
Brake lines for lift overlander Jeep CJ Forum 3 10-31-2003 05:34 PM
