do you think this tire can be saved? - JeepForum.com
post #1 of 13 Old 10-26-2002, 06:23 PM Thread Starter
onesojourner
i was stuck and some rocks cut the valve stem. and i couldnt change the tire where i was. think its saveable?
onesojourner is offline
post #2 of 13 Old 10-26-2002, 06:29 PM
93jeepyj2.5
93jeepyj2.5's Avatar
Arrow
Your pic isn't showing up on my computer.
-Heath
93 Black YJ, locked and on 33's----Sold
03 TJ Sport.....31" MT/R's on MT Classic II's
93jeepyj2.5 is offline
post #3 of 13 Old 10-26-2002, 07:32 PM
93jeepyj2.5
Arrow
Ok, the pic is showing up now.
You really cant tell if its saveable or not from the pic. I'd say put a new valve stem in it, air it up and see if it holds air, and let it go from there.
HTH
-Heath
post #4 of 13 Old 10-26-2002, 11:49 PM
CSP
Unless you damaged the cords inside the tire or cut the sidewall you should be fine. Take the tire off the wheel and check out the inside of it if you're really concerned about it. Myself, I would just put in a valve stem, air it up, and see what happens.
CSP is offline
post #5 of 13 Old 10-28-2002, 06:02 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
If its no good for the highways .. it could be saved as a trail-only spare ..
Check it out .. no harm in that.
How did you like that ProComp tire before it popped off the bead?
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #6 of 13 Old 10-28-2002, 06:08 PM Thread Starter
onesojourner
well i only had it out a few times with the new tires, on the rocks i like them alot. they havnt seen a hole lot of mud. we are in a drought where i live.
post #7 of 13 Old 10-28-2002, 06:46 PM
CSP
Oh please! There's no way you can tell from that picture if the tire is damaged or not. Sure it's wrinkled some, but that happens to tires that are allowed to go flat sitting in one spot. Without seeing what the inside of the tire or the belts look like theres no conclusive answer any of us can make via the internet.
onesojourner it would have been helpful to know how far you drove it without any air. I would hope that you didn't go far. I can't think of any trail ride I've been on where a suitable spot couldn't be found to change a tire within 100 yards of where it went flat. Even on uneven ground you can change a tire with caution. On something like this if you don't know what to look for you should take it to a tire shop and let them determine if it's good or not. I would hate to see you spend the money on another tire if this one isn't damaged. Tires are pretty damn tough if you don't get them too hot.
CSP is offline
post #8 of 13 Old 10-28-2002, 07:51 PM Thread Starter
onesojourner
it got pulled about 100 yards with both the tires flat. it was in a semi dry lake bed and it was starting to rain and we feared it would get flooded with run off soon.
post #9 of 13 Old 10-28-2002, 08:12 PM
Jeepfreak81
Jeepfreak81's Avatar
Hey ... might wanna re-read what naekid wrote it says IF it isnt acceptable for highway use... not that it isnt at all.... Two different meanings but yeah try a valve stem first or if it looks iffy in person take it to a tire shop and ask...
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #10 of 13 Old 10-28-2002, 09:55 PM
CSP
Yep you're right, I misread it! My apologies NaeKid. Thanks for pointing that out Jeepfreak.
CSP is offline
post #11 of 13 Old 10-29-2002, 02:41 PM
NaeKid
NaeKid's Avatar
Not a problem .. I was kinda confused as to what you were tryin' to say there ....
I have a tire that barely holds air .. just enough to drive on for about 4 hours before I have to refill it with some pressure (ya, I know, I should fix it .. ), so I just use it as a "trail only" spare .. get to the highway where I could make a better repair to whatever is blown ..
Silver
NaeKid is offline
post #12 of 13 Old 10-29-2002, 10:35 PM
Jeepfreak81
im possibly looking at a "trail only spare right now" i took my tire i popped on my last trail ride with GHJEEPYJ94 and they said the hole is where the sidewall and tread meet -- looks more in the tread to me so i am going to tire slime it and see what happens -- cant afford another tire right now, and im not planning on the same size tires next time around
post #13 of 13 Old 11-03-2002, 07:14 PM
werewolf7111
ok, let me give you some tire advice( my first job was with Michelin as an engineer)
assuming the tire shows no obvious sign of physical damage
1) check rim, clean and inflate to about 50 PSI( for safety I have to say in a tire cage)- this is assuming the bead area has no gouges
2) check sidewalls for and ridges, bubbles or anything but smooth flat even surface( this is EXCLUDING the normal sectionwhere the plys are bound in the frame process and a straight line)( telltale signs are "skews"[ places where the rubber looks like it turns])
3) spin the tire on a balancer and see of any separation has occurred( make sure rim warpage isnt confused with the tire proper)
4) balance the tire
assuming the tire passes all these tests- it normally can be considered good
couple of tire facts all may want to know( these are industry standards)
1) NEVER repair a tire with anything but a PATCH/PLUG( this is a cold patch with a plug made onto it-reason being the #1 CAUSE of tread separation and tire failure has been determined to be a tire repair thathas allowed water and road salt to get into the belting and corrode/electrolosize it)- a patch covers the hole and holds air- but leaves the original damage to get contaminated
2) never attempt any sidewall repair( its not an air hold thing- but a structural integrity thing) if you have to due to prices of tires- patch it but put a tube in it also
3) for proper tire life- keep pressure right- heres the field test used- clean tread and soak concrete with water- drive and look where the water clings to the tread- a proper footprint will beapp 1/4" from the OUTSIDE of the water siping on the tread- on a CJ- this is 25 PSI ( do NOT let those ratings fool you- those are MAXIMUM ratings at FULL LOAD- theyare NOT what the tire is designed to run at under regular conditions- REGARDLESS of tire size or rating- its SOLEY based on vehicle weight)
4) avoid these fix/flat things at all times( read the fine print- they DEGRADE rubber and if left in tires for long duration- make further repair unreliable)
5) keep tires out of sunlight( either armorall or in a shed)
hope this helps
Joe MSME PE
werewolf7111 is offline
Coas............or someone with his TFI/HEI/MC2100 link saved.... Blthomas Jeep CJ Forum 38 11-15-2007 08:28 AM
Can this tub be saved? ETJeep Jeep CJ Forum 14 02-21-2007 11:04 PM
I lost my saved links..... Blthomas Jeep CJ Forum 3 08-29-2006 09:08 AM
AMC 360 - Can it be saved bdmonist Jeep CJ Forum 8 07-28-2006 07:37 PM
Saved from the Scrap Heap aviator Jeep CJ Forum 3 08-11-2003 11:46 AM
