Quantcast Do I need a vacuum reservior can - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Do I need a vacuum reservior can
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 03-08-2009, 04:21 AM   #1
a2tripp
Where can you find them? Are they necessary after the nutter? Thanks
04 tj, nothing special
a2tripp is offline   Reply With Quote
Old 03-08-2009, 07:35 AM   #2
petey156
1977 CJ5
i think those are for really radical cams, that dont produce enough vac at idle.
petey156 is offline   Reply With Quote
Old 03-08-2009, 08:12 AM   #3
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Most CJ's don't have them.
Now if you are talking the gas tank and carb float bowl vent, the charcoal canister, yes you need it or you have to put up with raw gas fumes. It is also needed to balance the flow to the stock PCV valve which controls engine sludge.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 03-08-2009, 09:38 AM   #4
Oily
My last CJ7, an 83, and my current 85CJ7 both have them. Neither were hooked up. What are they for ?
Oily is offline   Reply With Quote
Old 03-08-2009, 09:49 AM   #5
Mike Romain
Off Road Forever
Usually for a flavor of emissions controls I believe. I think things like cruise control would use one also. YJ's have them for the vacuum front axle control.
Mike
Old 03-08-2009, 10:17 AM   #6
Oily
I did follow them here. Could not make out what they did. Looks like it helps the idle of the carb.
Old 03-08-2009, 10:22 AM   #7
6leafclover
1974 CJ5
I never had a vacume can or charcoal can on mine, runs good and i dont really smell the gas fumes, its the exaust fumes that get me from having straight pipes with no cats or mufflers
6leafclover is offline   Reply With Quote
Old 03-08-2009, 11:06 AM   #8
jfwireless
1976 CJ7
So how do you vent your gas tank?
Jim
jfwireless is offline   Reply With Quote
Old 03-08-2009, 11:27 AM   #9
Tshark299
1987 YJ Wrangler
From the factory my vacuum reservoir was connected to the solenoids on top of the valve cover that controlled the Pulse Air system. The axle disconnect on my YJ did not use the reservoir, only a straight manifold vacuum line to the transfer case, and then to the front axle. After removing the non-functioning Pulse Air system I reused the reservoir for the axle disconnect... it seems to connect a little quicker but it was pretty reliable before hand so I'm not sure if it made a difference.
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
'95 XJ - Donated drive train to the YJ, Parting the rest out
'51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline   Reply With Quote
Old 03-08-2009, 05:17 PM   #10
a2tripp
Well the emissions are out, I will probally just cap those two lines off and ditch the can. I still plan on keeping the charcoal canister. I have heard that you could replace part of the filter on the bottom but I can't find it, any ideas?
Old 03-08-2009, 07:47 PM   #11
RED85
Mine is "not stock",but it stores a vacuum to operate the power brakes if the motor should stall.
It's nice to have some brakes (one or two pumps of the pedal beats, none everytime)
RED85 is offline   Reply With Quote
Old 03-08-2009, 11:45 PM   #12
a2tripp
is that what the can does, provides extra vacuum to the booster?
also, is the charcoal canister rebuildable, i mean can you change that filter like stuff on the bottom like some say? if so with what/ how?
Old 03-09-2009, 01:00 AM   #13
RED85
that what my can does, provides "stored" vacuum to my booster.
charcoal canister rebuildable, i don't think so .... but i might be wrong ....i like to know if replaceing the darn thing is the only option.
Glock Forum
