Do i need a radio? - JeepForum.com
post #1 of 6 Old 07-03-2013, 01:30 PM Thread Starter
Jack718
1972 CJ5
Do i need a radio?
I have been doing some digging but haven't been able to get an answer. I'm wondering if I can play my music with my iPhone through the speakers without the radio. I have a radio it just doesn't have an auxiliary and it's in an overhead console that I would just like to get rid of. I also have an amp in it, will that help me? Not to good with these electronics so any help will be greatly appreciated.
Jack718 is offline
post #2 of 6 Old 07-03-2013, 01:33 PM Thread Starter
Jack718
1972 CJ5
I just saw a thread below mine with a very similar question. Sorry for the repeat question.
Jack718 is offline
post #3 of 6 Old 07-03-2013, 01:43 PM
stamp32
Yes you can...all you need is an amplifier. You use an RCA to 3.5mm headphone cord and plug it into the red and white inputs of amplifier. You control the volume with the iPhone.
stamp32 is offline
post #4 of 6 Old 07-03-2013, 01:58 PM Thread Starter
Jack718
1972 CJ5
That's great, thanks. I found it online and am definitely going to order one. Thanks again.
Jack718 is offline
post #5 of 6 Old 07-03-2013, 03:23 PM
bajaviking
1976 CJ7
This is basically the setup i have in mine. In my case to power the amp I ran a mainpower line to feed the amp(use good cable) and a switched power to turn it on and off. I think the switched power is usually handled by the carstereo which in this case is not part of the system.
76 CJ7 6 cyl/t18/Dana 20
05 TJ HP30/8.8 with ARB's Rubicrawler Flatbelly Midarms/3" lift and 35s
bajaviking is offline
post #6 of 6 Old 07-03-2013, 04:38 PM
agear
This is cool.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
