do i need to drop tran/transfer case - JeepForum.com
post #1 of 15 Old 03-11-2010, 07:25 PM Thread Starter
k2dott
i have a 79 cj7 and i plan on putting a 4in rough country lift kit on it. do i need to drop the tran? is there anything else i need to do for this lift to work. thanks
k2dott is offline
post #2 of 15 Old 03-11-2010, 07:27 PM
Matt_G
1979 CJ5
i would save a little more and go with something other than rough country, i've heard only bad about those. (ride wise, their kits are decent)
Matt_G is offline
post #3 of 15 Old 03-11-2010, 07:30 PM Thread Starter
k2dott
thanks but that doesnt help me out any. lol
k2dott is offline
post #4 of 15 Old 03-11-2010, 07:36 PM
Coiz
1979 CJ7
On most 4" lifts you will want to lower the cross member. It all comes down to driveline angles really.
Mike
Coiz is offline
post #5 of 15 Old 03-11-2010, 07:37 PM Thread Starter
k2dott
think i could just use washers or do i need a kit?
k2dott is offline
post #6 of 15 Old 03-11-2010, 07:39 PM
DaveinHouston
My 4" RC lift came with a TC drop. I took it out when I installed an SYE and CV driveshaft.
- 2003 Rubicon - 4" Lift, 35" KM2s, 5.13 gears, winch
- 1968 CJ5 - Dauntless V6, T-86, Dana 18, D27 & D44
- NRA Life Member - Licensed to Carry and Do.
DaveinHouston is offline
post #7 of 15 Old 03-11-2010, 07:42 PM Thread Starter
k2dott
dumb ? but what kinda drive shafts are those? lol
k2dott is offline
post #8 of 15 Old 03-11-2010, 07:44 PM
Coiz
1979 CJ7
By a piece of 1x1x3/16" 6 feet long and cut it to length. Drill holes, buy longer bolts and you're done.
Mike
Coiz is offline
post #9 of 15 Old 03-11-2010, 07:44 PM Thread Starter
k2dott
well i just looked at the kit im gonna order and it has a drop kit, thanks anyways!
k2dott is offline
post #10 of 15 Old 03-11-2010, 08:37 PM
mtbtweety
mtbtweety's Avatar
1982 CJ8
OP,
Remember this post when you come back to the board asking how to get a better ride....
mtbtweety is offline
post #11 of 15 Old 03-11-2010, 11:29 PM
jeepmaster03
1982 CJ7
Also check to see if the RC kit had a drop pitman arm, longer sway bar links (or drop brackets), and longer brake lines. These Items are usually not in a budget priced kit.
jeepmaster03 is offline
post #12 of 15 Old 03-12-2010, 05:46 AM
gmakra
The answer to the original question drive it after the lift and see if you have drive line issues. And yes you can use fender washers and longer bolts if you need to.
gmakra is offline
post #13 of 15 Old 03-12-2010, 06:30 AM
southshore30
1982 CJ7
Look into what Jeepmaster said. Lots of times you will end up spending more money on one of those budget kits in order to get the other stuff you need. In the long run, buying a nicer lift kit for a little more gets you all the stuff you need in one package and gives you a better ride with better quality springs that aren't going to sag down to a 2.5" lift after a year. Save yourself some headaches too and go with a double cardan/CV style rear driveshaft after the lift and leave out the TC drop. Price out Tom Woods or Tatton's shafts, they are about the same. It will save you a lot of U joint woes.
southshore30 is offline
post #14 of 15 Old 03-12-2010, 12:04 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Of course if you have a Q trac, your driveline angles may no be a problem. Perhaps you could fill in your profile.....
jeepdaddy2000 is offline
post #15 of 15 Old 03-29-2010, 09:25 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
They are double-cardan driveshafts. People that don't know the difference between a double-cardan joint and a constant velocity joint call them CV's (mistakenly). Unfortunately, a lot of vendors also call them this, perpetuating the problem. Same deal with people and gear vendors calling high pinion gearsets "reverse rotation". They don't rotate in reverse. The gears are reverse cut, meaning the spiral goes in the opposite direction. The gears still rotate in the same direction as standard-cut (low pinion) gears.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
Transfer Case Drop Kit Needed? JUNK726 Jeep CJ Forum 4 07-12-2009 02:48 PM
cj transfer case drop muddmonky Jeep CJ Forum 5 02-14-2008 05:06 PM
Transfer case drop 1980tallcj7 Jeep CJ Forum 4 02-22-2007 05:05 PM
Transfer Case Drop mustangdave357 Jeep CJ Forum 3 03-28-2006 10:48 AM
transfer case drop calcallender Jeep CJ Forum 11 02-25-2006 08:10 PM
