Do I need degree shims? - JeepForum.com
post #1 of 29 Old 10-24-2012, 03:13 PM Thread Starter
Turtle71
1983 CJ7
Trying to track down the steering slop, delay, or what some may call wander.
I have replaced some tie rod ends. New shackles and bushings. Adjusted toe. Ball joints seem to be ok. I checked the steering shaft and can turn it very slightly with my had before I see the pitman arm move. Steering box doesnt move since I tightened the bolts.
To measure caster, I used an angle meter type tool (which isnt the greatest but free).
Here are some pics. The green line represents level and the gray ruler looking thing represent actual. The top grey box measurement is the one to pay attention to.
Inside of front drivers wheel under lower ball joint:
Inside of passenger wheel under ball joint. Facing opposite way.
What do you guys think?
My 83 CJ7 Build:
Turtle71 is offline
post #2 of 29 Old 10-24-2012, 03:44 PM
CSP
I can't quite grasp where your measurement is, but assuming it's from the correct spot your first picture has 4.29 degrees of positive caster (assuming the front of the Jeep is to the right of the picture). That's pretty light. It would be happier in the 6-7 range. Looks like the other side has even less.
CSP is offline
post #3 of 29 Old 10-24-2012, 04:24 PM Thread Starter
Turtle71
1983 CJ7
You are correct on the orientation of things. So 6-7 degrees would be better?
My 83 CJ7 Build:
Turtle71 is offline
post #4 of 29 Old 10-24-2012, 06:11 PM Thread Starter
Turtle71
1983 CJ7
This is a pic I found showing the area I was measuring from.
My 83 CJ7 Build:
Turtle71 is offline
post #5 of 29 Old 10-24-2012, 06:13 PM
82JeepCJ7
1982 CJ7
How long are your front shackles?
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #6 of 29 Old 10-24-2012, 06:14 PM
skizriz
1978 CJ7
Looks in the 3* range in that picture. Is the floor level where you are parked? If it slopes a degree or two that needs to be taken into consideration.
skizriz is offline
post #7 of 29 Old 10-24-2012, 06:33 PM Thread Starter
Turtle71
1983 CJ7
They are 4" shackles
My 83 CJ7 Build:
Turtle71 is offline
post #8 of 29 Old 10-24-2012, 06:35 PM Thread Starter
Turtle71
1983 CJ7
To clarify, that last picture is not mine. Its just shows the spot where I measured at as CSP was unsure.
My 83 CJ7 Build:
Turtle71 is offline
post #9 of 29 Old 10-24-2012, 10:47 PM
82JeepCJ7
1982 CJ7
The longer shackles will tilt the top of the axle forward, decreasing the caster angle and making the steering wonder. You should have around 6 or 7 degrease of caster.
post #10 of 29 Old 10-25-2012, 01:32 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
So, to answer your original question, some 2 degree shims should put you right in the sweet spot, assuming your method of measure is accurate.
I found the method you are using somewhat inaccurate. It's probably only good to about +/- 2 degrees. Personally, I'd take it to a shop and get good numbers before I did anything.
Matt
Matt1981CJ7 is offline
post #11 of 29 Old 10-25-2012, 08:18 AM
CSP
Yeah, the bottom of the knuckle isn't the most accurate. It's a cast piece that isn't machined in that area, so it's a crapshoot at best.
CSP is offline
post #12 of 29 Old 10-25-2012, 10:19 AM Thread Starter
Turtle71
1983 CJ7
I agree on that. Im sure taking it to a alignment shop is the best idea to be accurate. Just having trouble finding time during the week. I tried to measure on top of the upper ball joint castle nut but there wasn't enough room. Any other areas to measure?
My 83 CJ7 Build:
Turtle71 is offline
post #13 of 29 Old 10-25-2012, 02:52 PM Thread Starter
Turtle71
1983 CJ7
I called a reputable alignment shop in town to get an idea of what to expect. He said $45 since you can only adjust the tie rod and drag link. When I asked about degree shims for caster, he said he thought that was for earlier Jeeps but would check that out too. Hopefully I can get some accurate caster measurements at least. I imagine its a lot cheaper to do the shims myself. Anyone have a shop do this for them? Or know what it would cost?
My 83 CJ7 Build:
Turtle71 is offline
post #14 of 29 Old 10-25-2012, 07:20 PM
Matt1981CJ7
1981 CJ7
Turtle,
For $45 it's worth it to get accurate numbers.
Once you have those, you can order the correct shims and throw them in yourself. It's pretty straight forward.
Good luck,
Matt
post #15 of 29 Old 10-25-2012, 07:49 PM Thread Starter
Turtle71
1983 CJ7
I think that's the route I am going to go. Just wondered if a shop might have shims and do it at a good price since their other quote was reasonable.
My 83 CJ7 Build:
Turtle71 is offline
