Do I need Ballast Resistor - JeepForum.com
post #1 of 35 Old 07-09-2010, 06:07 PM Thread Starter
mjeckell
1979 CJ7
I have a 1979 cj7 v8 304. I have upgraded to a larger MSD cap, rotor, and blaster 2 coil. Spark gap at .045. I also put 8.5mm MSD plug wires in. I am still using the ford duraspark ignition module. I bought the good one they had which I believe is the borg warner brand at O'reillys. I have also ran a dedicated ground to the black wire coming off the distributor.
A mechanic today was looking under the hood and asked why I had the ballast resistor in there and I said thats what the painless wiring diagram said I needed. He said in response that would be needed if it were stock but that I have upgraded the coil, cap and rotor. He explained to me that cranking with the resistor gives me the 12v needed but running that voltage is cut around half to about 6v. He went on to say that 12v is needed for the blaster 2 coil.
What do you guys think? Is he right or would this be bad for the ignition module if I removed the resistor.
- Matt
mjeckell is offline
post #2 of 35 Old 07-09-2010, 09:57 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
i have the painless harness with the motorcraft ign system with an msd coil and team rush upgrade...been running it like this for about 3-4 months and it has been fine without the resistor
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #3 of 35 Old 07-10-2010, 12:48 AM Thread Starter
mjeckell
1979 CJ7
any other opinions?
mjeckell is offline
post #4 of 35 Old 07-10-2010, 08:27 AM
BioTex
1979 CJ7
Doesn't the factory coil say "for use with external resistor" stamped on it? That leads me to believe the coil could fail with out it. If you have a coil designed for "no resistor", then I would think you are OK with out one.
I'm not 100% though!
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #5 of 35 Old 07-10-2010, 08:46 AM
VACJ7
VACJ7's Avatar
I think the resistor is there to keep from burning up the duraspark ignition module. At least on later years.
VACJ7 is offline
post #6 of 35 Old 07-10-2010, 09:08 AM
BioTex
1979 CJ7
Must be, because why else have it!
Currently:
BioTex is offline
post #7 of 35 Old 07-10-2010, 09:48 AM Thread Starter
mjeckell
1979 CJ7
How could they build a ICM that could not handle the 12v supply. I dont understand?
Matt
mjeckell is offline
post #8 of 35 Old 07-10-2010, 10:43 AM Thread Starter
mjeckell
1979 CJ7
What I am confused about is the resistor is right at the coil. Doesnt it just reduce the coil voltage in the run position and give 12v at cranking? If so, wouldnt the ICM always receive 12v. Little confused.
mjeckell is offline
post #9 of 35 Old 07-10-2010, 10:49 AM
77j20
1977 J-Series Truck
If you have an upgraded coil you shouldn't need it. I took mine out when I did the TeamRush on my truck. I'm pretty sure that the blaster coils have an internal resistor. Your best bet would be talk to JeepHammer.
1977 J-20 TeamRushed AMC 401, TH400, D44 front, D60 rear, 33x12.50R16.5 Mud Terrains, SOA, rear shackle flip.
77j20 is offline
post #10 of 35 Old 07-10-2010, 10:50 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Duraspark needs a resistor...it can't stand a full 12v.
HEI, as some folks convert to, you have to take the resistor out...it wants the full 12v.
Your Duraspark module will be fried with 12v.
I was under the impression that the stock resistor was a resistor WIRE, though...not that old-timey firewall-mounted resistor like shown in that diagram.
Pacfanweb is offline
post #11 of 35 Old 07-10-2010, 10:54 AM
77j20
1977 J-Series Truck
But if his new coil has an internal resistor he is just throwing another resistor in there. I wouldn't think the Ign module cares how many volts you are throwing at your coil.
77j20 is offline
post #12 of 35 Old 07-10-2010, 11:14 AM Thread Starter
mjeckell
1979 CJ7
That is whats confusing isnt the module always getting 12v and isnt the resistor only affecting the coil?
mjeckell is offline
post #13 of 35 Old 07-10-2010, 11:21 AM
77j20
1977 J-Series Truck
From what I understand and from the diagram above that is how it should work. Your 12v going into the ICM is spliced in before the resistor so therefor it should have no effect on the ICM. Probably the easiest thing to do is to give MSD a call and see what they say about running a resistor. I tried looking, but everything I can find doesn't say whether the blaster coils have internal resistors or not.
77j20 is offline
post #14 of 35 Old 07-10-2010, 11:26 AM
77j20
1977 J-Series Truck
According to the MSD website you only need the resistor if you are running points. I would still give them a call though just to be on the safe side.
77j20 is offline
post #15 of 35 Old 07-10-2010, 11:30 AM
nitecop
Wrong,
The factory duraspark HAS a resisitor in the wiring. You will be better off withOUT an added resistor.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
ballast , resistor , cj
Ballast resistor omfdcapt2 Jeep CJ Forum 12 03-06-2010 08:15 AM
0.8 ohm ballast resistor 1979CJ53043SPD Jeep CJ Forum 1 11-14-2008 08:40 PM
Ballast Resistor on 24V ChrisHelvey Jeep CJ Forum 3 03-14-2006 10:17 AM
Ballast Resistor on 24V ChrisHelvey Jeep CJ Forum 0 03-13-2006 03:49 PM
Where is ballast resistor exactly? fromme Jeep CJ Forum 8 10-27-2004 01:36 PM
