do I need to align my CJ post-lift? - Page 2 - JeepForum.com
post #16 of 18 Old 03-02-2012, 08:04 AM
SoK66
2009 JK Wrangler
By all means re-set the caster if it changed as a result of the lift. In most cases it should be OK, but if you installed longer shackles (such are supplied with the Rubicon Express kits) at the same time it will reduce your caster. The longer shackles drop the front of the spring, thus tipping the caster angle down. Don't use aluminum shims, they'll wear quickly and eventually split in half and get spit out. Use steel shims of the type that are held in place by the spring pack centering pin.
The best fix is to cut the spring perches off and weld on a new set with the caster dialed in. However, this is a big, expensive job and steel shims will do the trick.
SoK66 is offline
post #17 of 18 Old 03-02-2012, 08:33 AM
noahlon
1968 CJ5
The biggest thing I noticed after a 2" lift was flat towing. It didn't turn as easy as it did before the lift and wouldn't straighten out right away. I added a 2 degree shim and now is back to normal, follow's correctly and turns and returns straight as it should.
noahlon is offline
post #18 of 18 Old 03-02-2012, 09:11 AM Thread Starter
aBoyAndHisCJ
1978 CJ7
Noah, that's a nice color rig you have there my friend. Mine is flat green as well, but a much more drab green. I like yours.
The problem with Jeeps is that everyone fancies himself some kind of Adventurer after he buys one. As if courage, or ruggedness, can be had for a mere $27,745 MSRP
aBoyAndHisCJ is offline
alignment , cj7 , steering , steering alignment
replaced steering box....how do you align? clarythedrill Jeep CJ Forum 7 11-02-2011 05:13 AM
CJ5 Soft top door don't align w/ windshield darwood112 Jeep CJ Forum 11 10-10-2008 02:56 PM
How to align a CJ5 Hardtop and Doors? Jeff5886 Jeep CJ Forum 17 02-28-2008 08:17 PM
cj7 steering column will not align (HELP) jpnkavu Jeep CJ Forum 5 01-06-2007 03:28 PM
78 T-150 Clutch align tool? hfjeff Jeep CJ Forum 7 02-19-2003 07:25 PM
