Do I have a starter problem? - JeepForum.com
post #1 of 11 Old 09-13-2013, 03:34 PM Thread Starter
radshooter
1963 CJ5
The last couple times I started the CJ left me wondering if the starter is going south.
When I turn the key, the engine will turn over a few times then stop, but the starter will continue to whirl until I release the key. Once in a great while the engine will turn until I release the key, but usually it is "turn-whirl".
I just dropped in a new battery (thanks LumpyGrits ) so I don't think that is a problem.
Do y'all think it is the starter? Drive gear? I've never messed with either. How hard are they to change out?
Thanks everyone..
I will really be glad when I get smart enough to start answering questions instead of asking them all the time!
radshooter is offline
post #2 of 11 Old 09-13-2013, 03:50 PM
JustDandee
1983 CJ7
I would say that you are in the market for a new starter. Sounds like the bendix "drive gear" is spinning on the shaft.
JustDandee is offline
post #3 of 11 Old 09-13-2013, 03:57 PM
WillysCJ
1976 CJ6
Those starters work on inertia so if you look at the top of your starter theres a cover that you can remove. In it there is a arm that on one side has a magnet and on the other side the finger that pushes the drive gear forward. They are prone to get dirty and then the drive gear does not fully push out.
Take the starter off and clean that mechanism properly and give it some WD40 or other can lube. Youl quickly see that you can fix this yourself once you open up that cover. You do not need to open the whole starter on the long screws.
WillysCJ is offline
post #4 of 11 Old 09-13-2013, 05:01 PM
ADDZ71
1979 CJ7
Let me ask a related question. Over the past three weeks or so one out of every ten cranks will result in a grinding noise. IT doesn't happen every time. Sometimes I alleviate the problem by roll starting it. I have not pulled it off to inspect / clean the bendix gear but the randomness is what concerns me. Knowing that the flywheel typically stops in discrete stops related to compression strokes on the engine I would be a little concerned of a ring gear having a bad spot.
Thoughts?
ADDZ71 is online now
post #5 of 11 Old 09-13-2013, 05:40 PM Thread Starter
radshooter
1963 CJ5
Thanks guys. I guess I know what I am doing this weekend! Along with finding out why the front hubs won't lock in. And getting the gas gauge to work. And finding out why the heater doesn't work. And putting on steps for the wife to get in and out. And.,..........Does this ever end?????
post #6 of 11 Old 09-13-2013, 05:42 PM
jumbojeepman
1976 CJ7
Thoughts?
My thoughts concur with your thoughts - i.e. bad ring gear on flywheel.
jumbojeepman is offline
post #7 of 11 Old 09-13-2013, 05:57 PM
carnuck
1984 J-Series Truck
Make sure it's not just the starter coming loose (VERY common on AMC motors!)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #8 of 11 Old 09-14-2013, 05:28 AM
WillysCJ
1976 CJ6
Ring gearmis very unlikely to be the problem but possible. Start with starter drive gear and cleaning it properly.
WillysCJ is offline
post #9 of 11 Old 09-14-2013, 01:38 PM
LumpyGrits
You either have teeth missing on the ring gear on the f'wheel, or buggered up Bendix spring and gear on the starter.
Get a new starter and see what happens.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #10 of 11 Old 09-14-2013, 08:52 PM
jumbojeepman
1976 CJ7
LG
Or take out the starter, and spin around the engine with a breaker bar while you look at the ring gear teeth through the starter hole with a flashlight. It's usually pretty easy to see which ones are messed up.
post #11 of 11 Old 09-15-2013, 07:09 AM
JeePete
1983 CJ7
When the starter was working well (in the recent past), were you getting any grinding? That would be the tell tale of a bad ring gear/flywheel.
If the starter wasn't loose and you need a "new" starter, I'd suggest trying to find someone to rebuild the stock unit, (or exchange it). Those were similar to the old Ford set ups & easy (simple & cheap) to rebuild. Hopefully the guy is using genuine bendix etc.
Unless you can find an honest brand name starter somewhere, the Chinese crap is, well, crap & you'll be replacing it again soon.
Just my .02
JeePete is offline
