do axle ratios need to match? - JeepForum.com
post #1 of 15 Old 06-30-2012, 07:21 PM Thread Starter
shadoow
saw another thread on here discussing axle gear ratios & it sounded like front & rear axle ratios may not have to be the same.
i've got an 85 cj7 w/258. Front is a dana 30 and rear is a dana 20. Both have 3.31 gears. I'm looking to replace the dana 30 with used/rebuilt one & am wondering if I need to get a 3.31 axle to match the rear. If not, what ratios would work for me?
shadoow is offline
post #2 of 15 Old 06-30-2012, 07:27 PM
FLynes
De Oppresso Liber
FLynes's Avatar
1976 CJ5
They must match. You can get away with .01 or so difference, i.e. 3.54 and 3.55, 4.10 and 4.11, etc...
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #3 of 15 Old 06-30-2012, 07:33 PM
B52dude
Well, technically, if you run different sized tires in front and back, you could use different ratios in the axles. But you generally don't see that. Nor do I recommend it. Because it will look dumb.
Originally Posted by Ripper3494 View Post
i think we should chase him around with yjs, its like being chased by zombies, slow, crippled but for some reason still scary as heck lol
Red Jeep Club #614
B52dude is offline
post #4 of 15 Old 06-30-2012, 10:23 PM
80cj
80cj's Avatar
1980 CJ5
Ford used 3.54 front and 3.50 rear for years with no problems.
80cj is offline
post #5 of 15 Old 06-30-2012, 10:28 PM
mopar346
You guys are nuts they don't need to match as long as you don't put it in 4WD and lock the hubs everything will be fine, you can run any ratio with any other.
Manufactures have run them a few hundredth off front to rear for years, still not sure way.
Careful your character's showing
mopar346 is offline
post #6 of 15 Old 07-01-2012, 01:01 AM
Skerr
If you are replacing the D30 with another D30, and the gears are still good, you could swap them into the new axle. What's the problem with the current D30?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #7 of 15 Old 07-01-2012, 01:12 AM
80cj
80cj's Avatar
1980 CJ5
In answer to the OP's original post, yes you would have to get another 3.31 axle because there is no other ratio available in a D30 that is close.
80cj is offline
post #8 of 15 Old 07-01-2012, 01:46 AM
firewalker909
firewalker909's Avatar
1973 CJ5
The way it was explained to me at mek-a-nik school, the higher gears were used in the front to create a pulling action, as opposed to a pushing action from the rear. Supposed to be more stable off road.
There was a guy at my school in Phoenix that had replaced his gears in the rear of his Toyota pick up with a higher gear set. He literally climbed all the hills in Deer Valley backwards. Don't remember off hand what the ratios were, but pretty sure the guy had a screw loose anyway.
firewalker909 is offline
post #9 of 15 Old 07-01-2012, 01:49 AM
80cj
80cj's Avatar
1980 CJ5
Guys who run mud a lot do that and I imagine it would work well in soft sand too but don't forget to disengage 4WD when you get on a high traction surface.
80cj is offline
post #10 of 15 Old 07-01-2012, 05:52 AM
colojeepguy
1970 CJ5
I had a '66 F-100 with that setup. It was a great ol' truck, but I used to have to stop & back up to get it out of 4WD.
colojeepguy is offline
post #11 of 15 Old 07-01-2012, 05:59 AM
hp_lovecraft
1981 CJ5
I had a CJ5 years ago that the PO swapped in another axle with mismatched gears.
I didn't know any better and just ran it anyway. I had no problems offroad, but it would bind and be nearly impossible to get out of gear. If I hit a hard surface, the tires would hop and skip.
For the OP, maybe you will be fine in the shortterm, but its going to put more strain on the driveline. Eventually something is going to go.
hp_lovecraft is offline
post #12 of 15 Old 07-01-2012, 08:12 AM
Skerr
Ditto!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #13 of 15 Old 07-01-2012, 10:41 AM
80cj
80cj's Avatar
1980 CJ5
I ran into the same situation back in the 70's with a 70 CJ-5 that I bought and was told it had 4.88's. As it turned out, the front was 4.88 but he broke the rearend and subsituted a 44 from an M38A1 which was 5.38. Very difficult to get out of 4WD and the slip yoke splines on the front drive shaft were very loose. Ended up getting my money back.
80cj is offline
post #14 of 15 Old 07-01-2012, 04:24 PM Thread Starter
shadoow
gears are probably shot. The pinion yoke wiggles around in the housing and i've seen metal bits in the oil i drained. Didn't take a close look when i did the oil cause i hadn't yet found the pinion wiggle. I had recently got the jeep & was going thru doing fluid changes.
Besides the gears, i'm concerned the housing may be internally damaged.
thanx all for the info on gear ratios. Guess i'll continue my search for a 3.31 replacement.
shadoow is offline
post #15 of 15 Old 07-04-2012, 10:06 PM
FLynes
De Oppresso Liber
FLynes's Avatar
1976 CJ5
Hopefully this helps you:
http://www.ebay.com/itm/Jeep-CJ7-CJ-...5d187e&vxp=mtr
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
Front/Rear axle ratios dont match??? 00rooster Jeep CJ Forum 7 12-17-2011 06:52 PM
what axle ratios in 1980 hold24 Jeep CJ Forum 2 06-21-2009 08:43 PM
Idenifying axle ratios TravellinMan_15 Jeep CJ Forum 6 03-15-2009 02:59 PM
Narrowtrack rear axle with 2" spacers match up with a widetrack front axle? Blthomas Jeep CJ Forum 1 05-11-2007 09:25 PM
T-150 and axle gear ratios... certifiablejeep Jeep CJ Forum 2 08-16-2004 12:54 PM
