Dizzy Gear - JeepForum.com
post #1 of 8 Old 10-17-2009, 03:01 PM Thread Starter
tgarey
1978 CJ5
Dizzy Gear
The 258 in the CJ5 threw a huge backfire and then died, would not start no matter what I did. Crank all day, no start.
Pulled the distributor cap and realized the rotor could be turned 360* by hand; bad!
Pulled the entre dist. and found no gear on the end; very bad!
Finally got the oil pan off (have to raise the engine about 2-in.) and found the gear in the bottom of the pan, no excessive wear however the roll pin had sheared off flush with the dist. Shaft; sort of good.
Near as I can tell, it fell into the pan when I lifted the distributor out of the engine.
Also found the two little pieces of the roll pin that used to go through the gear in the pan. So, at least I found all the loose hardware and it wonít end up somewhere where it can do serious damage.
Did a search and found tons about gears being eaten, but that's not my situation.
The distributor is an HEI upgrade and when I put it in I used the old gear and pin. Iím thinking I should have used a new pin at that time, however the pin was tight when I put it in. Has anyone else had the roll pin that holds the gear on the end of the distributor shaft shear off and if so, what type of roll pin did you put back in? I really don't want to do the "remove the oil pan", ďfind TDC and reinstall the distributor again.
tgarey is offline
post #2 of 8 Old 10-17-2009, 03:39 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Has the oil pump been upgraded to a hi-volume or hi-pressure one? Those pumps put extra loads on stuff not designed for the load.
Rick
Cutlass327 is offline
post #3 of 8 Old 10-17-2009, 05:25 PM Thread Starter
tgarey
1978 CJ5
No, I left the OEM oil pump in it. Could a bad backfire cause this?
tgarey is offline
post #4 of 8 Old 10-17-2009, 05:41 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Possibly. I guess if the pin was weak or something and the engine jerked hard enough.. Don't know.
I've heard hard powershifting a lot can damage dist parts from the sudden up/down of the rpms. ANy truth to that don't know.
Rick
post #5 of 8 Old 10-17-2009, 05:48 PM
Fjguercio
1978 CJ7
How long and miles has the HEI been installed?
inspect the cam gear for wear and damage?
verifty the oil pump is not bound up??
Does the gear fit shaft properly, does the distributor bottom out with colar meating the block/gasket surface.
Something sheered it off. How long a period of install and how many miles should have been in post 1.
Fjguercio is offline
post #6 of 8 Old 10-17-2009, 06:00 PM Thread Starter
tgarey
1978 CJ5
Installed in April of this year, maybe 200 miles on it. I can turn the oil pump easily with a screwdriver. The cam gear looks good, minimal wear. The gear is a running and sliding fit over the shaft.
That's why I'm at a loss as to why it sheared, perhaps just an old pin. Just wondering if anyone else has had this experiance.
Tadd
tgarey is offline
post #7 of 8 Old 10-18-2009, 07:26 AM
JeepHammer
Running On Empty...
1973 CJ5
Many of those cheap distributors had shafts and/or housings that were too long and they put the oil pump in a bind.
When you do that, it either strips the teeth off one (or both) gears,
Or it shears the roll pin.
I would look to see if the housing seats on the block WITHOUT a gasket.
This will tell you if the housing seats.
Then try and work the distributor shaft up and down a little while holding the housing in place.
If you have some 'Play' in the shaft, doesn't take much, then the shaft isn't binding the oil pump.
I say WITHOUT a gasket because the gasket is going to compress over time, and you need to see if there is enough clearance when that happens.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #8 of 8 Old 10-18-2009, 01:25 PM Thread Starter
tgarey
1978 CJ5
Thanks JeepHammer, I'll do that to make sure there is enough room for the shaft. Picked up the new oil pan gasket today and a roll pin. Probably be able to work on it over the next day or two after work.
tgarey is offline
Dizzy drive gear stephens_cj5 Jeep CJ Forum 5 10-28-2009 07:28 AM
oil comming out of dizzy. Axlesnap Jeep CJ Forum 12 03-27-2009 05:52 PM
Proform HEI swap, OE dizzy gear won't fit BradMB2004 Jeep CJ Forum 2 06-28-2008 07:10 AM
ECU and distributor Dizzy takisanjeep Jeep CJ Forum 1 04-22-2007 07:43 PM
Greasing the dizzy? Ol' Roy Jeep CJ Forum 1 11-06-2006 05:26 PM
