Distributor, wobble. - JeepForum.com
post #1 of 8 Old 05-27-2009, 10:02 AM Thread Starter
Beninpcb
1982 CJ5
Is it normal for the distributor to have some wobble, i was under the jeep had it running and my distributor had a somewhat noticeable wobble to it. Is this normal, and if not what do i need to do to fix it?
Beninpcb is offline
post #2 of 8 Old 05-27-2009, 10:11 AM
scottymac62
1979 CJ7
No, it's not normal for a dizzy to wobble. Is your lock down clamp secure? Is it a stock Duraspark dizzy or some aftermarket DUI?
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #3 of 8 Old 05-27-2009, 10:24 AM
papaj
1979 CJ5
Are you sure it wasn't an "opical dilution" from vibration? Like the wobbling straw trick.?
Grab it and try and move it.
papaj is offline
post #4 of 8 Old 05-27-2009, 10:49 AM Thread Starter
Beninpcb
1982 CJ5
no it definitely wobbles, i will take a pic of it and post it so you can see. it's on an 82 CJ5, 4cyl. when the engine is off i cant move it. but when its running the whole unit has a wobble. do i need to replace it?
Beninpcb is offline
post #5 of 8 Old 05-27-2009, 11:55 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I've never seen anything good come out of a wobbling distributor. But now you have to find out why there is a problem before you put in a new one and it starts to wobble.
IS the engine original? maybe someone bent the distributor housing when removing the engine.
John Strenk is online now
post #6 of 8 Old 05-27-2009, 12:37 PM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
Mine too was wobbling the other day... turns out mine had a crack in it... right at the base near the clamp hold down... I have never seen anything quite like it... although right before I found it, I noticed a bit of a miss under load.
I have a new one on the way, but when I took it out, the outer housing definitely is cracked and not in great shape.
Sucks, but I am glad I caught it when I did.
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #7 of 8 Old 05-27-2009, 03:05 PM Thread Starter
Beninpcb
1982 CJ5
how do i find the crack, if there is one?
Beninpcb is offline
post #8 of 8 Old 05-27-2009, 04:12 PM
certifiablejeep
Bicentennial Nickel
1976 CJ5
Mine was at the base, you couldn't miss it.
Also, could your distro have been bent maybe on the bench, or shelf prior to install?
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
304 '75 Prestolite distributor vs 304 '78 distributor Dad03 Jeep CJ Forum 19 08-26-2009 08:50 AM
HEI Distributor 47redwillys Jeep CJ Forum 12 07-30-2009 09:22 AM
Need A Distributor TEXASROCKWELL Jeep CJ Forum 4 07-14-2009 09:09 AM
bad distributor? durdenclub Jeep CJ Forum 3 09-13-2004 07:55 PM
Distributor OKJeepin Jeep CJ Forum 3 04-05-2004 04:11 AM
