Distributor rotor does not turn - JeepForum.com
post #1 of 5 Old 06-03-2012, 05:24 PM Thread Starter
jsmoe
I am fixing up a 1980 CJ5 with the GM 151 4-cylinder engine.
The engine overheated while driving and turned off as I coasted to a stop.
The engine will not start but does turn over and is not seized. I checked the plugs and was not getting a spark. I pulled the distributor cap and the distributor rotor does not turn when the the engine is cranked (by starter or manually).
It does not seem to be the timing belt as I can crank the engine and determine TDC on piston #1.
I have not pulled the distributor as I didn't want to mess up the timing, but that is my next move.
Any suggestions or comments would be appreciated.
jsmoe is offline
post #2 of 5 Old 06-03-2012, 05:31 PM
scottymac62
1979 CJ7
Timing is useless to you if your dizzy is not spinning. Yank that baby out and see if its the dizzy gear or your cam gear that is messed up.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #3 of 5 Old 06-03-2012, 06:11 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
"It does not seem to be the timing belt as I can crank the engine and determine TDC on piston #1"-jsmoe
Doesn't that just mean the piston is still connected to the crank? Or did you pull the valve cover to make sure the intake is closed near TDC? I may be a moron and missing something, so please don't take this as me being snarky.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #4 of 5 Old 06-03-2012, 06:22 PM
gojeepgo
1981 CJ7
Turning the crank by hand will still make the piston go up and down in the bore even if the timing chain is broken. It is possible the cam is not turning as you crank the engine which would indicate the timing chain is broken. The dizzy turns via a gear on the camshaft. You can pull the valve cover off and turn the engine by hand. If the valves are not moving then the chain is broken.
gojeepgo is offline
post #5 of 5 Old 06-04-2012, 06:37 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Finding TDC has nothing to do with the timing belt/chain, you can do that with just a crank in a block.
Now if you're talking about finding the compression stroke, the belt/chain has to be intact for that to happen.
Pull your oil filler cap off (assuming it's in the valve cover) and have someone crank the engine....you'll be able to see if the rocker arms/valves are moving, that'll tell you if your belt is still on.
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
cj5 , distributor , overheated , rotor , turn
Can't turn distributor any more... Outnumbered Jeep CJ Forum 24 03-31-2012 10:26 PM
Should rotor turn when crank is turned? Tigerpaw Jeep CJ Forum 3 03-18-2012 08:12 PM
Rotor attachment to Distributor replaceable? mnCJ7guy Jeep CJ Forum 5 07-03-2011 06:27 AM
75 cj5 304 rotor and distributor donkey77 Jeep CJ Forum 3 05-27-2009 06:32 PM
Which way does rotor turn? (Timing Advance) qwert98 Jeep CJ Forum 6 05-01-2007 07:36 PM
