Distributor Drive Gear Issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Distributor Drive Gear Issue
Unread 02-08-2016, 05:08 AM   #1
Myjeep1986
Cj Distributor Drive Gear Issue
I am sure its been discussed over and over as a problem, but I am hoping somebody has the permanent solution. I have now chewed up 2 gears. I do not believe I have short changed the products or the quality. Have a stock AMC 360, did the FI conversion (carb was RPIA), changed to a HEI.
When I had my 72 Wagoneer (2) and then an 86 Grand Wagoneer, never had an issue like this. Jeep looks great except it tends to spend more time on a flat bed and at shop.
Myjeep1986 is online now   Reply With Quote Quick reply to this message
Unread 02-08-2016, 07:30 AM   #2
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
It's a common problem with the cheap clone HEI distributors and AMC V8s.
You need to buy the drive and cam gear as a set to insure they don't eat each other up.
Summit sells them.
Matt
Matt1981CJ7 is online now   Reply With Quote Quick reply to this message
Unread 02-08-2016, 07:36 AM   #3
jblue1555
1979 CJ7
have you replaced the timing chain and gears in the past? if so your problem maybe there.
jblue1555 is offline   Reply With Quote Quick reply to this message
Unread 02-08-2016, 09:30 AM   #4
texasdave
texasdave's Avatar
1980 CJ7
I agree with Matt. Most of the time it results in differing hardness of the two gears and the weaker one will crap out.
texasdave is offline   Reply With Quote Quick reply to this message
Unread 02-08-2016, 12:58 PM   #5
AllenForaker
1975 CJ5
If you have destroyed two distributor gears, you need to give your cam drive gear a good looking at. I just replaced mine. When I put the new engine in back in 2010, I dropped in a new HEI from Jeggs and didn't know or care about the gear mesh, I just installed it and forgot about it. 7000 miles later my timing would not retard when idled down. Pulled the distributor and it's gear was in great shape. But, a look down at the cam gear showed razor sharp edges where the distributor gear had worn them down. I surmise this happened within the engines break in time because I had absolutely no metallic particles in the oil or filter when I pulled the timing cover. In that 7000 miles I have changed the oil twice and didn't think to check for particles in the break in oil. I replaced both gears with an MSD matched set, and they are not cheap and after about 20 engine hours now, no wear can be seen on either gear.
Allen
AllenForaker is offline   Reply With Quote Quick reply to this message
Unread 02-08-2016, 04:35 PM   #6
Myjeep1986
Thanks Allen, I need to check with my mechanic, thought we did that the first go around. I will keep you posted on the results.
Unread 02-09-2016, 08:41 PM   #7
AllenForaker
1975 CJ5
I also fabricated a Timing Gear Oiler when I put it back together. Someone else's idea I read about somewhere, but it makes sense and it works.
Allen
Unread 02-10-2016, 02:07 AM   #8
lucdog
lucdog's Avatar
1980 CJ5
Good question, and if the gear on the cam was changed, was the flashing cleaned out in the oil passage?
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 02-10-2016, 10:01 AM   #9
Cashcrazy
Cashcrazy's Avatar
1983 CJ7
I just went through the something similar and was able to locate the issue. I wouldn't run it anymore until you located the issue. You don't want the metal particles getting pushed into the bearings.
If it was me this is what I would do... Go ahead and order a matched set of gears and a timing cover gasket set. I'd order a timing chain set also if you know the one in it is original with high mileage. Pull the accessories and timing cover and inspect the timing cover for anything unusual. The timing sprocket has a key way notch and an oil passage. Make sure these are installed correctly and the oil passage does not have flashing blocking the path. Check the new sprocket oil passage also. I cleaned the flashing up on mine with a small file before installing. I have read about people using a drill bit to test the hardness of the two gears. I would try this to see if one of the gears is a hardened steel and the other not. Otherwise you're just replacing the gears and hoping it doesn't happen again. I like to find the cause if possible. I have not done the HEI on a V8, but Think you have to get the AMC modified HEI with the correct shaft length and not just run the Chevy HEI like you can in the 258.
1982 CJ7(sold), 1983 CJ7(sold), 1989 YJ(sold), 1983 CJ7 undergoing frame-off.
Cashcrazy is online now   Reply With Quote Quick reply to this message
Unread 02-10-2016, 10:16 AM   #10
Cashcrazy
Cashcrazy's Avatar
1983 CJ7
One other thing, put assembly lube on the new gears when installed. Don't want to run a new set dry at startup.
