Disc brake conversion question - JeepForum.com
post #1 of 2 Old 03-28-2007, 01:02 PM Thread Starter
Tractor Boy
1977 CJ5
So I got the donor axle out of a 78 that turns out to be the 7/8" rotors. Just about everything comes off smoothly except for the spindles that are like welded on from 30 years of rust. Been soaking them with pb with no luck so far. Now I'm wondering if my wheels are going to clear the rotors. I have the big drums on the front. What do guys think? Is this a great forum with priceless information or what?
Tractor Boy is offline
post #2 of 2 Old 03-28-2007, 02:47 PM
John Brereton
The way to get the spindles off is to beat the snot out of them with something hard, but not harder than the spindles. You don't want to dent them up. Bang them one way, and then the other. Eventually you'll start to see a parting line between the knuckle and the spindle. Once you see that, take a small flat head screw driver and tap it into the parting line to act as a wedge. Then beat the spindle the other way (against the screw driver). When you see a parting line form on the other side, insert another screw driver into THERE. Repeat the process, changing to larger screw drivers as necessary, and the spindle will walk off.
Another way is to take a brass drift pin and band at the back of the spindle (through the back of the knuckle). This also works but it is a pain to insert the big brass drift pin.
There IS a difference between drum brake wheels and disc brake wheels. You might get lucky with '78 since it was a transition year for Jeep, but then again, you may not. You'll have to try them out.
What's left of a '79 CJ5
3 - 4" total lift
4.88 gears in a Dana 30 and off center ff Dana 44 with disc brakes
258 with TFI /T18 /D18 drive train with Saturn O.D.
33 x 12 DC Mud Country Radials
John Brereton is offline
CJ disc brake conversion ? NCHornet Jeep CJ Forum 11 12-06-2007 07:47 PM
CJ7 Disc Brake Conversion for REAR Jonnyhaku Jeep CJ Forum 3 04-16-2007 07:42 PM
Disc Brake conversion CJmadison Jeep CJ Forum 4 02-24-2006 03:14 PM
Disc brake conversion question AvyZJDriver Jeep CJ Forum 1 12-18-2005 10:40 AM
AMC20 Conversion to disc brake CJ10a Jeep CJ Forum 4 02-20-2002 08:17 AM
