Disc Brake conversion - JeepForum.com
post #1 of 5 Old 02-23-2006, 01:02 PM Thread Starter
CJmadison
I have a 1985 CJ7, amc 20 with one piece axles. any ideas for upgrading to Disc brakes? Looking for a cheaper solution instead of buying the SSBC Kit.
CJ Madison
2006 TJ... bone stock
CJmadison is offline
post #2 of 5 Old 02-24-2006, 08:16 AM
gosupes
Do a search over on the Pirate forum. There was a writeup using basic parts from a couple of different cars. Pretty low dollar from what I remember.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #3 of 5 Old 02-24-2006, 01:58 PM
jlynch
I used 77 scout rotors, 85 s-10 calipers and made my on brackets that bolt on. Had to do some grinding on the rotors to get them to fit over the axles. I also had to grind the brake pads down a litlle bit but it works fine. you might look at tsm's kit. pretty reasonable price but you have to buy the calipers seperate.
jlynch is offline
post #4 of 5 Old 02-24-2006, 02:02 PM
a84jeepCJ7
My advice is to check with TSM (www.tsmmfg.com) and get their kit (about $300). Then go to www.car-parts.com and order some calipers from a salvage yard. TSM will tell you what calipers you need. That's what I did. I am installing my brakes tomorrow and I'll let you know how they turn out.
a84jeepCJ7 is offline
post #5 of 5 Old 02-24-2006, 04:14 PM
dcarlton
I was planning on taking one of these routes as well, but ended up purchasing a whole new front axle for $250, included calipers, rotors, knuckles MC, porportioning valve & power booster. Also included new gearing, but am not putting that in.
I asked around at a local Jeep place, where all they sell is used Jeep parts, and that is where I got the axle from. We discussed these kits, or using parts from a Chevy Truck, but they really recommended against it, saying it is harder that people say, and more modifications are necesary.
My two cents.
dcarlton is offline
CJ disc brake conversion ? NCHornet Jeep CJ Forum 11 12-06-2007 08:47 PM
Drum To Disc Brake Conversion 68 Cj5 dstrebor Jeep CJ Forum 5 05-26-2007 01:37 AM
CJ7 Disc Brake Conversion for REAR Jonnyhaku Jeep CJ Forum 3 04-16-2007 08:42 PM
Disc brake conversion question Tractor Boy Jeep CJ Forum 1 03-28-2007 03:47 PM
How hard is a disc brake conversion? imtheant Jeep CJ Forum 5 04-08-2006 07:31 PM
