DIRECT BOLT tranny swap help - JeepForum.com
post #1 of 9 Old 05-11-2003, 03:46 PM Thread Starter
sampson9dk
I asked this question once before but need to ask again.
I have an 85 CJ7, 258, dana 300 t-case and a problematic T-5 tranny. Rather than bring it back to be fixed again id like to invest my $$$ in a better tranny. Im lookin for a DIRECT BOLT tranny replacement that is better than the t-5. I know Jeep used several trannys over the years. Cant I just use another one like the T176 or the Jeep version of the T-18. Im not up to a fancy swap that requires adapters, major mods or major $$$ right now I just want to drive it this summer (mostly on road use) I dont need anything that is bulletproof...just need somthing better than this sissy little T-5 that keeps breaking down.
I just cant believe that with the common 258 and Dana 300 there arent simple options.
Dave K
85 CJ7
MC 2150, electric fan, 33x12.5", no more crappy computer....keep it simple.
sampson9dk is offline
post #2 of 9 Old 05-11-2003, 05:36 PM
Jeep Daddy
Jeep Daddy's Avatar
As far as I know, only the T4 and T5 are direct bolt ins. The others require a different xfer case or adapters or mods. The Mustang tranny will work but the gearing will not be what you are looking for. There are WC T5's specially made for your application. They are $2k plus.
Even if you go T18 and a Dana 20 you will probably need new mounts, skid plate, and drive shaft mods. Also the floor holes may not be correct.
Others can chime in and correct me if Im wrong.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #3 of 9 Old 05-11-2003, 05:50 PM Thread Starter
sampson9dk
jeep daddy...thanks for the response....not what i wanted to hear but you are probably correct...My other thought was to get a donor CJ with a 258 and swap the tranny and t-case but I didnt know that I might have to Mod skid plates and drive shafts ect. Anyone else know anything about that??
post #4 of 9 Old 05-12-2003, 06:50 AM
only in a jeep cj
T-176 will work with your current transfercase and belly pan, but you will need that bellhousing. 2 bellhousing were used, one for the T-4, T-5, and SR4, and another one for the T 176, 177, and 150's. Both bolt up to and AMC 6 or 8 Cyl, but they have different trans bolt patterns. The T-176 will have the Dana 300 pattern on that end. You will gain some strength, and this is the least "effort" of a swap.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #5 of 9 Old 05-13-2003, 12:18 AM Thread Starter
sampson9dk
So if Im reading this correctly I can bolt the T176 right in from my donor CJ using the 176 bell housing. No drilling and tapping or drive shaft mods. Is that right??
Dave K
post #6 of 9 Old 05-13-2003, 04:47 AM
mxg342
mxg342's Avatar
you will probably have to cut/lengthen drive shafts. Or if you find a T176 just buy the driveshafts for it too.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline
post #7 of 9 Old 05-13-2003, 11:27 AM
kev1
Sampson9dk,
Check these people out. I have one of these transmissions, and can't wait until I get my jeep done. I talked to them a lot and they told me that they would warranty it even pulling my 20 foot boat. They also told me that they would stand behind it even if it was mounted behind a Chevy 350. Here is the URL:
http://www.5speeds.com/t5/jeep.html
Hope this helps.
Kevin
1980 CJ7 Rebuild:
Frame painted with a Rough Country 2.5" lift and shocks installed.
Alot of money spent on parts that are all over including a new 258.
kev1 is offline
post #8 of 9 Old 05-13-2003, 03:54 PM Thread Starter
sampson9dk
Kev...
I have seen that site before...If you really wanna help you can loan me $1375.00 ...Im still saving for new tires but if I get some extra $$ I may go with the WC T-5. Let me know what you think when you get it running
Thanks Dave K
post #9 of 9 Old 05-14-2003, 05:26 AM
mean green
the 176 is a good tranny on or offroad it is a strong tranny i have had no problems with it and i get on it when i'm offroading i think you would be happy with it
1985 cj-7,256, t-176,dana 300, dana 44's f & R ,detroit lockers f&r, 4.09 gears, soa with 4"suspension lift,2" shackle extention,shackle reversal,custom 3"x5" straight frame, custom roll cage with tire rack above, fiberglass body,35"s.s boggers,ramsey 8000lb winch
mean green is offline
is the the tf 727/300 combo a direct bolt up? kevchev Jeep CJ Forum 21 09-18-2009 07:31 PM
Better booster that is direct bolt in? BigDumbBear Jeep CJ Forum 13 02-02-2009 09:36 PM
RPMs after tranny swap. Which tranny? DT5150 Jeep CJ Forum 6 12-17-2008 05:24 AM
5 bolt to 6 bolt hub/lockout swap jollyroger Jeep CJ Forum 4 04-20-2008 12:59 AM
Tranny swap now with future engine swap in mind gestuhlm Jeep CJ Forum 1 04-23-2006 07:49 PM
