Dip stick tube - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Dip stick tube
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-13-2014, 11:12 AM   #1
Mlaughlin8
1980 CJ5
Dip stick tube
A there an easy fix to keeping my oil dip stick tube in place? Every time I check my oil and pull the dipstick, the tube comes right out with it... It doesn't leak or anything, it's just loose!
Mlaughlin8 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2014, 11:15 AM   #2
SeniorVerde
I got both surfaces real clean, and used a very small amount of JB Weld, being particularly careful to not let any drip into the block because it thins as it cures.
SeniorVerde is offline   Reply With Quote Quick reply to this message
Unread 03-13-2014, 03:57 PM   #3
rsg1963
CJ Slave
rsg1963's Avatar
1979 CJ7
Agreed on the JB Weld idea. Also, a muffler shop could put a tiny spot weld on there for you in two seconds. Not three, two. And that solution would be easily reversible if ever needed.
rsg1963 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2014, 06:10 PM   #4
keith460
Jeep. There's Only One
keith460's Avatar
I wouldn't use JB Weld for that as there are better products from Loctite that will do the job, like Bearing and Shaft Retaining Compound.
Freeze the tube in a freezer overnight and then coat with a small amount of Retaining Compound before inserting it back in the block. After 24hrs of curing time, that tube won't come out anymore unless it is heated with a torch to soften the Retaining Compound.
Loctite brands can be found at most auto stores.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is online now   Reply With Quote Quick reply to this message
Unread 03-13-2014, 06:25 PM   #5
strvger01
1966 CJ5
i've used Marine Tex. sold at most boat places, it does very well, imho. it has a better cure when it is applied very thick. i've used it on heads among other things. i always make sure i have some on hand. it's not cheap and it is a two part mixture.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline   Reply With Quote Quick reply to this message
Unread 03-13-2014, 11:00 PM   #6
Mlaughlin8
1980 CJ5
Cool, thanks for the replies! Will try this weekend
