differentials, oil, covers, and questions - JeepForum.com
post #1 of 4 Old 05-18-2003, 01:16 PM Thread Starter
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I figured I would show some pictures of my work this weekend.
I pulled off the differential covers and found a LOT of water and some gooooo that used to be differential fluid.
My questions are this.
I have a 1976 CJ-5 with a AMC20 rear and a D30 front.
I know water is bad in there, but what am I looking for when I take this apart to see if it is bad? It is my first time taking apart differentials on a 25+ year old machine. My 2001 Dodge Ram 1500 looked nothing like this.
Secondly, I am figuring this is unlocked from what I see in the pictures, but let me know if I am wrong.
Thirdly, I need to find out what gears I have in there. I am not sure if they have ever been replaced.
Front
http://photos.yahoo.com/bc/cb4158/vw...c=ph%26.view=t
Rear
And lastly, my humor for the day. You have to stay positive when you are sinking tons of money into your love.
Thanks for the info.
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #2 of 4 Old 05-18-2003, 07:21 PM
fuzz401
1978 CJ7
the first pic looks like it had water in it for shore the second looked like it had some water but not as much gears the tag on the rear should have 2 sets of numbers like 9-41 = 4.55 or jack up the rear mark the drive shaft turn the drive shaft till it goes 1 turn and see how many times the tire goes to the drive shaft = 1 drive shaft 3.5 tire turns
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 4 Old 05-18-2003, 11:16 PM
CSP
Another way to tell the gear ratio is to look at the stamp on the ring gear. It is on the side and will have the tooth counts of both the ring and pinion on it. Divide the ring gear tooth count by the pinion and you have the gear ratio. Should be pretty easy since you already have the cover off.
CSP is offline
post #4 of 4 Old 05-19-2003, 05:16 AM Thread Starter
certifiablejeep
Bicentennial Nickel
1976 CJ5
Well the cover is back on now so that is going to be a little hard. I guess I can do the jack up the rear end test and see now many turns the wheel does test as mentioned before.
Thanks!
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
What are my differentials?? shok47 Jeep CJ Forum 2 06-18-2009 08:26 PM
80 cj5 differentials? Tom1 Jeep CJ Forum 2 08-26-2008 12:27 PM
Differentials bfox48 Jeep CJ Forum 1 07-24-2006 01:52 PM
i need help with differentials diesel man Jeep CJ Forum 18 12-01-2005 04:27 PM
Seat Covers / Questions?? ksirmons Jeep CJ Forum 7 09-25-2003 06:29 AM
