different voltage - JeepForum.com
post #1 of 7 Old 06-10-2009, 06:56 AM Thread Starter
golferwt
different voltage
How come I get diff voltages at my accessories. All are below 12 volts. This is not typical cj7. Ford V8 302
golferwt is offline
post #2 of 7 Old 06-10-2009, 07:16 AM
iagmc
1974 CJ5
I would say it is "typical" of any conversion that the PO hammered there way through a project. My guess with such little information is that there is a voltage drop leading the the fire wall. I would check the wiring leading up to the wall and after. a partial broken fuse able link would cause a drop, of which you will have to find out why it tried to burn. I have take the stance of replacing fuse able links with a heavy circuit breaker and sealing them. I would not replace the link unless there was a problem. If some one stabbed a bunch of wires "looking" for a problem you could lose voltage there. The moisture will seep in and brake down wires through the whole. Which will cause a drop and not let amps through. In the right circumstances this could cause a fire. (unlikely but could)
Most people don't see the light till they feel the heat.
iagmc is offline
post #3 of 7 Old 06-11-2009, 04:27 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yes corroded/broken wires inside the harnes, bad terminals, crimps, loose connections will drop a voltage 0.1 volts here and there and by the time you add them all up, you get quite a voltage drop frome the source to the device. I bet your oltage gauge swings a lot when you turn on your turn signals also.
p.s. iagmc, fix your sig, I think it's suposse to be "felt the heat"
John Strenk is offline
post #4 of 7 Old 06-11-2009, 05:48 AM
rixcj
rixcj's Avatar
1979 CJ5
...or, FEEL...
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is online now
post #5 of 7 Old 06-11-2009, 06:04 AM
jfwireless
1976 CJ7
How are you measuring your voltage?? Where is the ground reference point you are measuring from?
You could have losses in your wiring harness or just bad ground connections or poor grounding method.
Try putting the negative lead of a voltmeter on the negative post of the battery and measure the voltage at each one of your accessaries to determine if it is a grounding issue or wiring harness issue. You may find different issues with each accessary.
Jim
jfwireless is offline
post #6 of 7 Old 06-11-2009, 07:14 AM
iagmc
1974 CJ5
thanks rich, My spelling is not the best, Always been my weak point.
iagmc is offline
post #7 of 7 Old 06-14-2009, 05:21 AM Thread Starter
golferwt
Thanks to all. Good areas for me to chk
golferwt is offline
Voltage Question fireslider Jeep CJ Forum 5 08-28-2008 10:00 PM
alternator voltage kappa505 Jeep CJ Forum 23 12-07-2006 09:02 PM
low voltage... jy4wvu Jeep CJ Forum 4 09-29-2006 03:54 AM
voltage MudMonster Jeep CJ Forum 30 04-05-2004 01:27 PM
Voltage Reg?? cj5mudman4x4 Jeep CJ Forum 3 02-21-2003 04:10 PM
