Quantcast Difference in old and new Dana axles ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Difference in old and new Dana axles ?
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 03-20-2005, 07:31 PM   #1
killah
Is there any difference in the new "old " model Dana axles and the old Dana's? Specifically what I mean is, do the Dana 30 and Dana 44 under my '75, have the same specs and build as the ones on todays Jeeps ( besides the coil vs. leaf changes)?
Just curious because it may be easier to get parts if they are interchangeable.
'75 CJ5, 1" Rancho lift, 31x10.5 A/Ts, [COLOR=red]A[/COLOR][COLOR=white]M[/COLOR][COLOR=blue]C[/COLOR] 304 w/ Performer carb, Performer intake, and fenderwell headers, T-Max 9500Lb winch.
killah is offline   Reply With Quote
Old 03-21-2005, 11:24 AM   #2
jeepskate
The newer Dana 30's used in Wranglers are high-pinion, so there's little to nothing you can use from them. The Dana 44 rears would be very similar (other than width and wheel bolt pattern).
jeepskate is offline   Reply With Quote
Old 03-21-2005, 01:35 PM   #3
contender54
I don't know the specific year,,,,but some of the old Dana 44s had coarse, 19 splined axle shafts.....I know postal jeeps etc had these.....not sure about CJ5 44s, though.
The later 44s are usually 30 spline
83 CJ7 IN PROGRESS: Warn 8274, Locked Scout D44 with 4.09s, rollcage, T18, Dana 300, Swampers, etc.etc.....
contender54 is offline   Reply With Quote
Old 03-22-2005, 08:42 AM   #4
Tshark299
1987 YJ Wrangler
The Dana 30 in '87-'95 YJs is high-pinion, but '97+ TJs use low-pinion. Also XJs used h-p until they switched to l-p, probably also in '97. Not sure how much is comptable though.
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
'95 XJ - Donated drive train to the YJ, Parting the rest out
'51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline   Reply With Quote
Old 03-22-2005, 11:45 AM   #5
lynn
IIRC the 97/up TJ D30s use a larger axle u-joint than the ones in your '75 D30, although I'm not exactly sure what year the change took place.. Of course, other differences include wheel mounting stud pattern, longer axles (wider stance) and disc brakes vs. your drums...
but as far as the ring/pinion/carrier go, they should be the same.
The D44 in your '75 is a 30-spline flanged axle. This would be the same internally as a TJ D44... but again your axles are much more narrow than the TJ, and have a different wheel mounting stud pattern.
Lots more info and many other '75 CJ5 owners on the Intermediates forum at www.earlycj5.com
Lynn
'05 LJ
EarlyCJ5.com Forums
lynn is offline   Reply With Quote
Old 03-22-2005, 03:48 PM   #6
80cj
80cj's Avatar
1980 CJ5
The TJ Dana 30 is a low pinion design as stated by others but it also differs from other 30's in that the pinion uses a crush tube to maintain bearing preload.
80cj is offline   Reply With Quote
Glock Forum
