difference between the CJ and the YJ - JeepForum.com
post #1 of 9 Old 10-03-2005, 01:36 AM Thread Starter
joeygeep
i own a 91 yj rite now and luv the cjs just as much but i dont know what the differences are really. and i mean everything except for the appearnce of like the hood and the lights. pros and cons to having a CJ?
1997 jeep wrangler tj sport 4.0
joeygeep is offline
post #2 of 9 Old 10-03-2005, 03:09 AM
kaibab
pros of the cj..everything...cons of the yj...everything....j/k....BURN your headlights
kaibab is offline
post #3 of 9 Old 10-03-2005, 07:12 AM
KGBnumber1
KGBnumber1's Avatar
uh oh we're going to go into the 'jeeps have round headlights' debate in here
Blue Jeep Club member #100
1970 DJ-5
3.8 v6
700R4 tranny
countless hours of blood and sweat turning it into a cj-5
KGBnumber1 is offline
post #4 of 9 Old 10-03-2005, 10:01 AM
only in a jeep cj
To answer the question, I mention the main points and compare a late CJ to an early YJ (91 on had fuel injection and a boxed rear roll bar).
Frame: YJ is 4 inches wider
Engine/ carb: same
tranny: both medium to light strength
t case: CJ is all gear and YJ is chain driven
Front axle: CJ has locking hubs (diff doesn't spin in 2wd) and YJ has no lock outs (diff spins while moving)
Rear axle: CJ had a 2 piece hub (most late CJ) and YJ had a C clip (most) CJ has 5 on 5.5 bolt pattern while YJ is 5 on 4.5
Springs: YJs are a tad longer and wider in front (yj also sits a tad lower)(CJ has more articulation)
Body: dashes are differnt, tailgate and hardtops are different, YJ has side mirrors on doors (same doors), gas cap on opp side, CJ windshield folds down in seconds, YJ has "Bars" bolted in, 85 on had fold n tumble rear seat on both, ETC.
Both will have a sway bar and have similar handling characteristics while the yj is a tad more road friendly and less off road ability and the CJ is opposite. They can interchange about 75 to 80 percent of thier parts. The problem is that a lot of folks try to compare a new Wrangler to the older style of CJ (pre 76) and there is a huge differnce there.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #5 of 9 Old 10-04-2005, 09:12 AM
390fastback
390fastback's Avatar
YJ's have galvanized tubs, CJ's don't. Thats why most guys put YJ tubs on their CJ's
2000 Cherokee
68 Mustang Fastback (in progress)
71 Mach 1
68 Wildcat (also in progress)
68 International 1200 4x4
78 F150 4x4 400 4spd
390fastback is offline
post #6 of 9 Old 10-11-2005, 09:11 AM
SgtSnake
SgtSnake's Avatar
Just had to throw in that a LOT of YJ stuff can be used on a CJ, you just have to know which. My CJ has a YJ hardtop, fits great, but I have to mod the rear of the top where the hatch meets the tailgate, due to YJs having the side-swing tailgate, and CJs having the drop down. I have to go inside and open my tailgate to open the hatch..
SgtSnake Former Jeep owner with plans to buy another within the next 2 years Cousin is currently rebuilding the old jeep, but need to buy rebuilt already.
SgtSnake is offline
post #7 of 9 Old 10-11-2005, 12:47 PM
JERSEYJOE
CJ vs. YJ
First of all, right on Ed ( Only in a CJ),
I have a CJ with a Wrangler tub and love it. I converted my YJ tub's tailgate to look like a CJ and moved the fuel filler to CJ style. It's easier to put an AMC v8 in a CJ frame since the mounts bolt up. The wrangler has welded in mounts and some trial and error is needed IF you are going to run some big HP. If you are it's considered way cooler to use an AMC V* vs. anything else.
CJ' S RULE!!!!!!!!!!!!!!!!!!!!!!!!
SPEED COSTS MONEY: HOW FAST DO YOU WANT TO GO?
JERSEYJOE is offline
post #8 of 9 Old 10-11-2005, 12:50 PM
JERSEYJOE
CJ vs. YJ
I have a CJ with a Wrangler tub and love it. I converted my YJ tub's tailgate to look like a CJ and moved the fuel filler to CJ style. It's easier to put an AMC v8 in a CJ frame since the mounts bolt up. The wrangler has welded in mounts and some trial and error is needed IF you are going to run some big HP. If you are it's considered way cooler to use an AMC V8 vs. anything else.
post #9 of 9 Old 10-11-2005, 04:23 PM
SgtSnake
SgtSnake's Avatar
Jersey Joe, I liked your post so much I had to read it twice!!
I'm also putting in a YJ airbox in my CJ , but there's an "extra" flap in the venting that I'm not sure of the reason for. it seems to have a see-thru tube that may close/open it with vacuum. I don't believe that was on the CJ one. I'll just keep it wired open til I can figure out how to use it.
SgtSnake is offline
difference between 72 and 76 cj5 davisjd Jeep CJ Forum 2 02-08-2008 11:24 PM
Difference between 304 and 360? gmshades Jeep CJ Forum 9 02-15-2007 06:35 PM
what is the difference thenubsterman Jeep CJ Forum 12 10-02-2006 06:05 PM
difference in cj7 canes989 Jeep CJ Forum 6 11-07-2005 12:26 PM
What is the Difference in CJ 5 and 7? Orange Juice Jeep CJ Forum 6 09-07-2004 11:17 PM
