Difference between 82- and 82+ Cj7 frame - JeepForum.com
post #1 of 7 Old 08-27-2013, 05:21 PM Thread Starter
patcj7
I got a 1979 CJ7 with 86 diff and I dont know frame year.
I want to buy a lift kit and I need to tell my frame year... what is the difference between 82 - and 82 +.
patcj7 is offline
post #2 of 7 Old 08-27-2013, 05:41 PM
VooDoo2
1978 CJ7
There isnt a differance. you will have wide track diff's so get some YJ springs (OME recommended) and your on the way.
VooDoo2 is offline
post #3 of 7 Old 08-27-2013, 08:08 PM
jeep_boy02
1980 CJ7
Frames from 76-86 should all be same. Of course hopefully any PO's havent mangled it too much. 82-86 will have tge wide track axles (4" wider I think, 2"per side) but all frame mount locations same
80 CJ7-304/T176/D300 HEI hdrs-WT D30/D44 4.56s, lockright/spool-SOA YJs W/RE AAL-35 MTRs beadlocks
jeep_boy02 is offline
post #4 of 7 Old 08-27-2013, 08:22 PM
spottedfrog
1979 CJ5
what about the upper front shock mount weren't the narrow track mounts short and welded to the frame, and the wide track mounts taller and bolted on?
spottedfrog is offline
post #5 of 7 Old 08-27-2013, 08:49 PM
jeep_boy02
1980 CJ7
I have an 80 narrow track, mine were bolted. I have taller mid 90's (iirc) F-350 mounts welded in place when I did the SOA back around 2000... am sitting on YJ leaves currently and in process of building a D30/44 combo out of an '86 to go wide trac. You could literally swap in wide tracks and not have to change leaves, mounts, shocks or drive shafts.
post #6 of 7 Old 08-28-2013, 07:42 AM
CSP
Shock mounts are different on '82 and up. There can be differences in crossmembers at the rear depending on year as well as skidplate bolt hole locations. For 76-77 they aren't boxed front to rear. Frames aren't exactly the same for the run from 76-86.
CSP is online now
post #7 of 7 Old 08-28-2013, 08:16 AM
VooDoo2
1978 CJ7
For the purposes of buying new suspension, there is no real difference. Read the OME thread (even if you dont buy those springs) as there is all the info you ever need in there about springs, shackles, hangers, YJ upgrades, shock lengths, SOA's, tie rod flips and much more.
http://www.jeepforum.com/forum/f8/ol...?highlight=ome
VooDoo2 is offline
