differance between a spun axle or sheared key on AMC 20? - JeepForum.com
post #1 of 14 Old 06-26-2010, 11:03 AM Thread Starter
81cjproject
1981 CJ7
Ok well wheeling with the 33 inch tires on stock two piece axles heard a loud
bang but was still able to get out of the mud hole and get home on the one rear that was still driving and 4 high. However how do I figure out if I need to replace whole rear left side ( if I do I am going one piece) or if I just sheared the key as another has suggested? the reason is if I go to one piece I have to replace entire carrier group because previous owner looks to have welded it all together. for strength? the 3 screws to get the drum off are rusted in bad.
81cjproject is offline
post #2 of 14 Old 06-26-2010, 11:22 AM
Skerr
When my axle spun on my 85 CJ7 I couldn't do ANYthing in 2WD. The PO had used a die grinder to expand the keyway in the hub, then he welded a bead on the spindle to match. That was the first of my plagues! You sure you have one rear wheel pulling?? Your PO welded the axle to the carrier??
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3 of 14 Old 06-26-2010, 12:52 PM Thread Starter
81cjproject
1981 CJ7
well not the carrier but he welded the shafts together in the middle all the teeth and what not. it has 1 back right wheel pulling still I can turn the driveshaft by spinning right drum but if I spin left drum it just chirps / squeaks and does not spin the drive shaft I can go start it and drive around in 2 wheel rt now just fine though. for a quick fix I just cranked down on the nut on the end of the spindle and it got tight enough to allow the tire to turn the drive shaft as soon as I got it off the lift though driving away the fist gas I gave it it went right back.
post #4 of 14 Old 06-26-2010, 02:16 PM Thread Starter
81cjproject
1981 CJ7
I don't plan on keeping this jeep alive I am looking for a cheap fix. I am in hawaii I deploy to afghanistan again soon and I am just going to beat the crap out of it and either part it or sell it if able maybe donate it to the blind if they want it. 81 cj7 that just has too many issues. and I don't have enough time.
post #5 of 14 Old 06-26-2010, 02:21 PM
slayer2000
slayer2000's Avatar
If I'm reading your post right it sounds like the po welded the spider gears up. If that's so then you're sheared the key. The axle still turns under power but the flange and the wheel won't. I don't have a lot of experiance with cj7s(I'm looking for one now) but I've heard guys welding the flange and nut to the axle as a temperary fix to get home on.
slayer2000 is offline
post #6 of 14 Old 06-26-2010, 05:15 PM Thread Starter
81cjproject
1981 CJ7
thats what I think happened too however I can't find any info on replacing the key or removing the sheared one.
post #7 of 14 Old 06-26-2010, 06:01 PM
only in a jeep cj
yup, put it should only be a temp fix...here's my write up on it with pictures
http://www.jeepforum.com/forum/f8/qu...un-hub-999835/
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #8 of 14 Old 06-26-2010, 06:05 PM
5-90
5-90's Avatar
1988 XJ Cherokee
A sheared key should still result in a solid keyway (may be mildly distorted,) while a "spun axle" usually results from a destroyed keyway.
Typically, the key is a shade softer than what it's retaining, so the carry of spare keys wouldn't go amiss (7/10 you'll fix it with a new key - at least enough to get home and inspect the keyway more thoroughly.)
Remove by removing the flange, then tapping lightly with a small mallet and punch. The shaft side of the key should have a rounded base, and you can tip it by tapping down on one end. The flange side will tap straight out of the keyway. If the shaft uses a straight key, you may want to grind a punch tip into a narrow wedge to drive under one end of the key in the shaft and lift it out (but a Woodruff key is usually shaped like a capital letter D.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #9 of 14 Old 06-26-2010, 11:36 PM
OldSailor
1977 CJ7
Sounds like you're ready for a set of one-piece axles, expecially since you're running 33's.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc.
OldSailor is offline
post #10 of 14 Old 06-28-2010, 10:51 AM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Yes.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #11 of 14 Old 06-29-2010, 02:04 AM Thread Starter
81cjproject
1981 CJ7
so I got drums off looking at hub how do I remove it to see the key / keyway? I think I just take the four bolts on the backside of it off but I need some help. I think it is just the key that is sheared though the axle shaft looks to be in good shape but the hub spins around it freely without turning the axleshaft. help any one?
post #12 of 14 Old 06-29-2010, 04:24 AM
Shasta69
1978 CJ7
sorry, but my Jeep-Fo is weak...
i will add a hearty THANKS for your service and BE SAFE!
retired e8
Shasta69 is offline
post #13 of 14 Old 07-03-2010, 04:10 PM
jeepwhore
Remove the big nut on the end of the axle shaft and pull the hub off. If the hub spun and you've driven on it a bit you shouldn't need a puller. For what it's worth, I wouldn't bother even trying to replace the key. Usually once a hub is spun.......thats it. The key way doesn't really hold the hub in place anyway but rather just aligns the hub and shaft so their splines align correctly. It's the splines, taper and torque oof the large nut that keep everything mated together.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #14 of 14 Old 07-04-2010, 03:37 AM
80cj
80cj's Avatar
1980 CJ5
Exactly!!
80cj is offline
Quick fix for Spun Hub only in a jeep cj Jeep CJ Forum 2 06-03-2010 05:03 PM
Think I just spun a rod. AMC 258 Big_Pete1999 Jeep CJ Forum 8 08-30-2009 02:27 PM
Spun a hub CJhollic Jeep CJ Forum 5 12-24-2007 11:11 AM
amc 20 spun, 1pc axle upgrade kfg Jeep CJ Forum 7 12-23-2007 09:51 PM
How do I remove this dang (sheared) axle from my 76CJ7 (pictures) part.changer Jeep CJ Forum 15 06-17-2007 09:18 PM
